4R70W in an AOD car - TCCoA Forums
post #1 of 12 (permalink) Old 07-08-2007, 09:50 AM Thread Starter
ClintD's Avatar
4R70W in an AOD car
as the title states, can this be done and still keep the L1C ECM?
I understand that I will need to add a switch for OD cancel. would I have to change a solenoid or add a relay?
The reason I want to keep the ECM is so I can keep the digital dash.
This will be for a 5.0HO engine. So the trans I get will have to be out of a 94 mustang.
ClintD is offline
post #2 of 12 (permalink) Old 07-08-2007, 10:13 AM
Yes, it can be done, but you can use later transmissions . . . there is a lot of information posted about which 4R70W transmissions are the strongest, and which of those will work behind a 5.0L/5.8L engine, as well as information about how to go about swapping a 4R70W in place of an AOD.
Just pop over to the Tech articles section, and select "Transmissions"; there you will find a multitude of information about the AOD/AODE4R70W, and while you're at it, you might do a search for "AOD to 4R70W"; you might just turn up something . . .
"Here" is the place you're located
"Hear" is what you do with your ears
"There" is another place
"Their" means it belongs to someone else
"They're" means "They are"
"Two" is a number
"Too" means "Also"
"To" is a destination
Stonecoldtx is offline
post #3 of 12 (permalink) Old 07-08-2007, 10:15 AM
twin turbo 281's Avatar
the newer 5.0 explorers had the 4rs i belive
2x95 cougars to the scapper
51 Mack A51T restoration
twin turbo 281 is offline
post #4 of 12 (permalink) Old 07-08-2007, 10:18 AM
5.0 Chero's Avatar
You will need a stand alone ECM for the tranny.
http://www.becontrols.com/products/tcs.htm
The Baumannator TCS is a revolutionary device which allows an electronically controlled transmission to be fitted to any vehicle, while providing infinite adjustability of all transmission functions via Microsoft Windows®. The features and specifications of the Baumannator TCS are described in detail within this document. If further questions arise, please feel free to contact Baumann Engineering by telephone at (864) 335-9365 or via Email us from our Contact and Company Info Page.
THE PYL !
91 Tbird lx 5.0 swap
GONE 93 5.0 Stang vert
86 F250 Diesel 4x4
GONE 89 Aerostar
2003 F350 Super duty
1996 Exploder
5.0 Chero is offline
post #5 of 12 (permalink) Old 07-08-2007, 12:09 PM
tbirdbrain's Avatar
Or there is the other option of building an AOD with a wide ratio gear set (from a 4r70w) which requires no additional control mechanism. If you go the 4R route, you would NOT want a early model 4r tranny. You would want a late model unit from a mustang (>2000).
I have heard mixed things about the baumannator (just ask dirtyd0g what he thinks, he will answer after he stops screaming ‘NO’ at the top of his lungs). I recently went the gearset route with mine because I wanted to keep my digital dash and I needed a better transmission with the power im making. I really wanted to do the 4R and distributor-less ignition system from an explorer but without the FF data feed from the ecu to the dash I wouldn’t do it. I like the dash (as do you it seems.)
tbirdbrain is offline
post #6 of 12 (permalink) Old 07-08-2007, 01:34 PM Thread Starter
ClintD's Avatar
So if I was to bring an AOD trans to a good trans shop and say I would like that done, Would they know what I'm talking about and approximately how much would something like that cost? More than $2000?
ClintD is offline
post #7 of 12 (permalink) Old 07-13-2007, 09:04 AM
Doubt they would tackle it, and if they did, proably not get it right...you need to find an expereinced swaper, or follow the tech files on CCR.
I think we forgot to mention the installation of the 3.8L . 4.2 L 4R70W and a MANUAL VB, it will come with a switch for both TCC lockup and OD. SO far a very likable swap by those that have done it.
www.Silverfoxtrans.com
www.clickclickracing.com
SilverFox is offline
post #8 of 12 (permalink) Old 07-13-2007, 12:39 PM Thread Starter
ClintD's Avatar
I'm debating on whether I should tackle this or not. I'm definitely going to have the AOD trans rebuilt and upgrade to a 2500 stall converter.
I was thinking of swapping out the parts and then bringing it to a shop to have everything rebuilt and set to spec, But the last trans I ever took apart was a 2 speed power-glide and I might be a little rusty.
My main problem is I have "Champaign dreams on a beer money income" as my Grandfather would say.
ClintD is offline
post #9 of 12 (permalink) Old 07-13-2007, 01:08 PM
Bradone's Avatar
Hey Silverfox,
I thought you said on your site you were considering building a few or did you change your mind?
Brad
[email protected] (engine/trans is stock)
Bradone is offline
post #10 of 12 (permalink) Old 07-13-2007, 01:09 PM
Bradone's Avatar
Here is the link to Silverfox's site with the details on the swap. Terrific site!
http://www.clickclickracing.com/foru...splay.php?f=12
Brad
Bradone is offline
post #11 of 12 (permalink) Old 07-13-2007, 01:22 PM
I don't build trans to sit around and hope they sell, just custom build each to the persons needs/desires. So that means no one has requested or I have found the need to build a WR AOD.
post #12 of 12 (permalink) Old 07-13-2007, 05:24 PM
Bradone's Avatar
You put it out that you would build on request "again" right after I found the one I have (you told me on your site just change the servo and run it). Your knowledge of the AOD is extreme as well as later models. I would have gone with you in a heartbeat. They will come. Seems most have forsaken the lowly oldster.
JMHO
Brad
Bradone is offline
