Mark VIII 4R70W Trouble - TCCoA Forums
post #1 of 4 (permalink) Old 07-13-2007, 08:05 PM Thread Starter
Hi,
I recently bought a '93 Mark VIII. Last week the car started shifting poorly. It holds 1st gear almost till redline at half throttle and it seems like you have to let off to get it to shift. It has also "neutraled" twice when I have punched on it. I'm not sure if it was the kick down from 3-2 or from 2-1. I have read a lot and I think it could be the 1-2 accumulator as I'm not sure if it was ever updated. Another strange thing that was happening whether related or not was every time I put the car in neutral or park the antenna would retract and cause the factory ten disc changer to error but if I was listening to the radio it would remain on. I have owned (and still do) a '91 T-Bird Sport for almost ten years and have lurked on these boards for a long time. I look forward to your responses.
dplammers is offline
post #2 of 4 (permalink) Old 07-13-2007, 08:14 PM
Bradone's Avatar
Originally Posted by dplammers View Post
Hi,
I'm sure some qualified people will be here soon but stop driving it till you get the answers or you will usually pay.
Brad
[email protected] (engine/trans is stock)
Bradone is offline
post #3 of 4 (permalink) Old 07-14-2007, 12:13 AM
Another case of a bad roller clutch it sounds to me.
Sorry to be the bearer of bad news your are going to need a rebuild or replacement transmission. You might try changing the mlps but I am doubtful it will fix this problem.
post #4 of 4 (permalink) Old 07-14-2007, 12:45 AM Thread Starter
Thanks for the reply. Anyway to diagnose it for sure? What points to the clutch over the 1-2 accumulator? Also have you ever heard of the strange radio issue?
Thanks a lot for your help.
