97 Mark VIII Trans into a 95 Bird - TCCoA Forums
post #1 of 16 (permalink) Old 07-26-2007, 01:12 AM Thread Starter
T-BIRDS281E's Avatar
I did a motor and trans swap into my car and I need to now what all needs to be changed in order to make that trans work? and if I cant then I will just put the old one from my bird back in But I don't want to!
1995 T-Bird DOHC 4.6L
True Dual Exhaust w/40 series flows
X Cal2 Custom Tune
18x8 ADR Kasai's W/ 245-40 General Exclaims UHP
A nice Little 10LBS. Bottle for a little EXTRA kick!
And Shinny As F*** Diamond Plate in the trunk!
myspace.com/BS_Johnson
T-BIRDS281E is offline
post #2 of 16 (permalink) Old 07-26-2007, 01:37 AM
SuperNewbie
supergordo's Avatar
are you using the mark 8 torque convertor? if so you need the mark flywheel. Otherwise the trans is the same. easy stuff
1995 Cougar XR7 4.6
1997 Thunderbird LX 4.6
1977 Country Squire 460
1985 Capri RS 5.0, 5spd
1997 Thunderbird 4.6
1984 Capri RS 5.0,5spd
supergordo is offline
post #3 of 16 (permalink) Old 07-26-2007, 01:48 AM Thread Starter
I dropped the whole set up in motor and trans all at once and it's in the car all ready! the pig tail on the trans are different then the one that came out to do I just change the harness mounted t the trans so I can plug in the one coming from in the car?
X Cal2 Custom Tune
post #4 of 16 (permalink) Old 07-26-2007, 07:13 AM
I think it depends on which PCM you are planning on running. If you are using the Mark VIII PCM and all the Mark VIII’s harness, cabling, etc. you shouldn't need to change anything.
If you are using the T'Bird PCM and the T'Bird's harness, you may have to repin the connector and make sure your solenoids in the transmission are the correct ones for the PCM. (I think… Hopefully some tranny guru's will chime in).
ON a side note, how do you plan on getting the Gen II's COP and the IMRC's to work?
69 F100 LWB w/460 Engine
post #5 of 16 (permalink) Old 07-26-2007, 07:24 AM
It's a 97 you shouldn't need to repin (that can be questionable on a 97 mark depending on production date) you will need the 95 tcc solenoid however. If the connector on the trans is white you are fine if the connector is black you need to repin.
post #6 of 16 (permalink) Old 07-26-2007, 08:54 AM
Dusty's Avatar
You should be good on the connector on a 97, need the TCC solenoid as Alan said. You also need the MLPS from the 95 Tbird assuming you are using the PCM and wiring from the TBird as Don asks.
Dusty is offline
post #7 of 16 (permalink) Old 07-26-2007, 10:09 AM
I will 3rd those comments.
www.Silverfoxtrans.com
www.clickclickracing.com
SilverFox is offline
post #8 of 16 (permalink) Old 07-26-2007, 11:02 AM
02 Explorer Pioneer
timb's Avatar
don't you also need the Tbird MLPS?
Birdless
timb is offline
post #9 of 16 (permalink) Old 07-26-2007, 12:46 PM Thread Starter
It had the white connector so i just changed out the wiring that piggybacks on the trans it's self and the thing that mounts to the gear selection had to be changed but thats it! So it looks like everything is good to go! Know is the 97 Mark trans any better like torque converter or internals at all!?
X Cal2 Custom Tune
post #10 of 16 (permalink) Old 07-26-2007, 12:57 PM
Sometime during the 97 model year, they upgraded them to better internals (98 spec). Unfortunately I don't know when the "change over" date is.
Just a WAG, but with the white connector you probably have an early model, but I am surely not a transmission guru.
post #11 of 16 (permalink) Old 07-26-2007, 01:01 PM
97 case is a little better than the 95 but same as another 97. TC is better than the standard larger one the TBirds get. I don't think there is anything in the internals that are better, might have the improved accumulator pistons, but the stuff like the direct clutch material is the same I THINK.
Bangster is offline
post #12 of 16 (permalink) Old 07-26-2007, 01:53 PM
Make sure you change the tcc or you will fry your pcm.
The markVIII converter is smaller and lighter. It stalls higher and has a higher top rpm rating. Otherwise the internals are pretty much the same. You will need the markVIII flexplate to use it.
post #13 of 16 (permalink) Old 07-27-2007, 12:08 PM Thread Starter
Whats the TCC?
X Cal2 Custom Tune
post #14 of 16 (permalink) Old 07-27-2007, 12:14 PM
Torque Converter Clutch solenoid.
Bangster is offline
post #15 of 16 (permalink) Old 07-27-2007, 12:34 PM Thread Starter
I thaught thats what it ment! lol were is it at in the trans and does any one have a pic of it! and why would it cause my pcm to burn up?
X Cal2 Custom Tune
post #16 of 16 (permalink) Old 07-27-2007, 12:41 PM
The resistance is incorrect. Too much current will pass through your pcm and it will fail. Change the TCC to the one that belongs with that vehicle and PCM.
