jmod (not a repost) - TCCoA Forums
post #1 of 9 (permalink) Old 09-06-2007, 12:17 PM Thread Starter
Send a message via AIM to Mellowout
jmod (not a repost)
hey everyone, i heard a while back from some post that i dug a few pages deep for that doing a jmod on a transmission that was slipping or acting improperly would kill it.
ive got around 95k miles on mine, and it doesnt slip, it just takes its sweet time to shift from gear to gear, usually i have to let off the gas before it shifts.
would a jmod fix that? or could it make it worse?
im beginning to think that they may have been thinking about a shift kit
Mellowout is offline
post #2 of 9 (permalink) Old 09-06-2007, 12:36 PM
jco1385's Avatar
have you checked your fluid?
1996 Cougar - 2004 3.9L 4R70W
jco1385 is offline
post #3 of 9 (permalink) Old 09-06-2007, 04:32 PM Thread Starter
i checked it a while back and from my understanding it was at an ok level
ill check again
i remember someone telling me that it wouldnt be something i would have to worry about too much
post #4 of 9 (permalink) Old 09-06-2007, 04:35 PM
jco1385's Avatar
not really, but if yours trans isnt going into gear, i'd say it needs to be checked. it could be that you just need to add some. also, you should probably change the filter anyways, so do a complete flush/refill with merc V.
jco1385 is offline
post #5 of 9 (permalink) Old 09-06-2007, 05:46 PM
SuperNewbie
supergordo's Avatar
I'm no expert here. However i just did the Jmod about 2 months ago. You replace the shift accumulator pistons when you do this, so that could help out the situation with the slow shifting. The Merc 5 could play a big part too.
Either way, if the trans is on its way out, its gonna go no matter what you do or dont do.
1995 Cougar XR7 4.6
1997 Thunderbird LX 4.6
1977 Country Squire 460
1985 Capri RS 5.0, 5spd
1997 Thunderbird 4.6
1984 Capri RS 5.0,5spd
supergordo is offline
post #6 of 9 (permalink) Old 09-06-2007, 05:49 PM
Chapter Director Coordinator
jamesD's Avatar
btw.. the Jmod is technically a shift kit of sorts.. using all ford parts
I bust ARP bolts by hand...
If Guns kill people, then...
...pencils miss spel werds
~Gun Owners of America
jamesD is offline
post #7 of 9 (permalink) Old 09-06-2007, 06:55 PM Thread Starter
yea i believe they were talking about the transgo kit or w/e it was called (i remember it being horrible)
i guess im gonna hit up the local transmission place, would they be familiar with a jmod for a tbird?
post #8 of 9 (permalink) Old 09-06-2007, 07:58 PM
It is nice
I doubt it, but its simple to follow the article so if you had the parts and information they should be able to do it for you. The j-mod itself is designed to help your transmission so if you had a failure its most likely from the condition its already in. Remember to either use mercon 5 or friction modifier like dr.tranny etc if you use mercon 3.
91CougarLS is offline
post #9 of 9 (permalink) Old 09-06-2007, 09:08 PM
Originally Posted by Mellowout View Post
i checked it a while back and from my understanding it was at an OK level
ill check again
i remember someone telling me that it wouldn't be something i would have to worry about too much
The heck with "checking" the fluid. It probably needs to be CHANGED. Upgrade the accumulators, stick a Jmodded valve body in it, fill it with Mercon V and be amazed at the difference.
I doubt the local transmission place would be familiar with the Jmod but it wouldn't hurt to ask.
