Overdrive switch - TCCoA Forums
post #1 of 8 (permalink) Old 12-14-2009, 09:32 AM Thread Starter
Andy625UK's Avatar
Overdrive switch
My overdrive switch started acting up the other day. I started the car and the light was on (o/d off), so I pushed the switch to turn it back on again, but the switch felt like the spring had gone a bit weak.
It happened a few times, then on Saturday I couldn't get the switch to turn the o/d on so I got hold of the switch to gently pull it back a bit, but the whole middle section of the switch button came out. I put it back in, and now it doesn't turn the o/d off at all. The button looks like it just pushes on some contacts in the shifter handle to work the o/d off function. It's not really a problem not being able to turn the o/d off, except sometimes on slight hills, or stop start driving when it would be handy.
Does it sound like the contacts have been flatenned, or am I missing a spring or something? I don't really want to have to fit a new shifter.
"...put me on a highway, show me a sign, and take it to the limit one more time"
The Eagles
1975
http://www.cardomain.com/ride/2149821
RIP Dutch T-Bird (Robert Hendriks) 1970-2012 No doubt looking down on us from his low-riding T-Bird in the sky.
Andy625UK is offline
post #2 of 8 (permalink) Old 12-15-2009, 07:47 AM Thread Starter
Andy625UK's Avatar
Cough
The Eagles
1975
post #3 of 8 (permalink) Old 12-16-2009, 08:02 AM Thread Starter
Andy625UK's Avatar
Is the overdrive switch is supposed to come apart?
Is there supposed to be a spring in there?
Can you buy a switch without buying a complete shifter knob (for a 1994 car)??
Would it be easier to bypass the existing switch and put a seperate one on the console somewhere?
The Eagles
1975
post #4 of 8 (permalink) Old 12-16-2009, 12:22 PM
The dealer sells the switch independently.
post #5 of 8 (permalink) Old 12-17-2009, 12:29 PM
Cough Snicker Cough
1995 Lincoln Mark VIII "Grandmas Car"
400,480 miles *STOLEN 04-13-08*
98 Mark VIII LSC
STONE
STOCK
SLOW
NO
MODS
HERE
XLRVIII is offline
post #6 of 8 (permalink) Old 12-17-2009, 02:27 PM Thread Starter
Andy625UK's Avatar
Ok I kinda knew the answer to that question.
When I couldn't get it to turn the od back on again I tried gently pulling the switch out of the handle, thinking it had got stuck in the "in" position. The thing just came out with no resistance at all! When I look into the hole I can see the copper contacts. I think they may have been flattened by the mechanic that test drove it. Maybe he thought he was pushing the main shifter knob or something (???).
I was thinking of seeing if I could gently pull the contacts back into shape. I don't want to end up with the od stuck off though.
The Eagles
1975
post #7 of 8 (permalink) Old 02-02-2010, 07:08 PM
There is a very flimsy copper contact built into a plastic case along the vertical shifter shaft. I had some issues years ago with putting it back in right after taking it apart for some work. There are only 2 wires going to it, you could run an external aftermarket switch in theory.
tbirdsc14 is offline
post #8 of 8 (permalink) Old 02-02-2010, 07:12 PM
As long as it's a Momentary (Normal Open) SP switch, should work fine.
Delete my account.
94 Thunderbird XX is offline
