2-3rd gear slide bump shift - TCCoA Forums
post #1 of 4 (permalink) Old 12-24-2009, 07:17 PM Thread Starter
Would a bad 2-3rd accum piston or spring cause a slide bump type shift from 2-3rd? Do I Have to remove the valve body to change it? Also what would happen if my VB screws were not torqued correctly? I losened them than tighten them before I installed my tranny.
95Goldbird46 is offline
post #2 of 4 (permalink) Old 12-25-2009, 12:24 AM
BUCK's Avatar
Thumbs down
DEFINITELEY have to pull VB to get to 2-3 Accum & delete Spring - Per Manual improperly Torqued VB Gaskets (about $8 for all 3 new Gaskets) will cause any number of really, REALLY BAD things to happen w/Tranny function - Get a proper Manual & be VERY careful under there~!
BUCK is offline
post #3 of 4 (permalink) Old 12-25-2009, 01:59 AM Thread Starter
Which spring? Lower or upper?
post #4 of 4 (permalink) Old 12-25-2009, 05:31 AM
There's only one.
