Tranny acts up - TCCoA Forums
post #1 of 32 (permalink) Old 01-15-2010, 05:15 PM Thread Starter
white lincoln's Avatar
Tranny acts up
On my 94 Cougar, the tranny will not shift out of 2nd sometimes. It seems to be random since it can happen in the morning when it is cold or after driving for a long time and you take off from a light.
I have done the J-Mod kit, tranny cooler, Transmission Position Sensor and have additives in the tranny oil.
To fix it, I drop the tranny into Neutral then back to Drive and it shifts into 3rd just fine after that and dosn't happen again.
I'd let it go, but it's the wifes car and she dosn't like to drive it now cause she worries... so now she drives my 95 Town Car and though I don't mind... it is my baby if you can understand that.
My first thought would be the TPS, but that was just changed out a couple years and less than 10k miles ago. I doubt it's the J-Mod kit cause the tranny preforms better than ever and better than my other cars.
Maybe low oil?
Maybe the TPS is bad again?
Do I have other problems in the tranny that could cause this?
white lincoln is offline
post #2 of 32 (permalink) Old 01-15-2010, 05:20 PM
I assume you replaced the accumulator pistons when you did the j-mod, right?
post #3 of 32 (permalink) Old 01-15-2010, 05:35 PM
beamerboy46350's Avatar
Send a message via Yahoo to beamerboy46350
heres a good link for the tps check: http://www.google.com/url?sa=t&sourc...wpUo3Q2Ex5doJg
92 Cougar LS 5.0: Air Silencer delete, Flowmaster Cat-back System, Big 3,Cold Air Intake,
77 BMW 530i(no longer running will come spring)
02 Caravan SE(DD 4 kids)
beamerboy46350 is offline
post #4 of 32 (permalink) Old 01-15-2010, 06:32 PM Thread Starter
Of course. Both 1-2 and 2-3. Left the springs out too.
post #5 of 32 (permalink) Old 01-15-2010, 06:45 PM Thread Starter
Sorry, I was talking about the transmission position sensor or shift position sensor. Sorry I don't have the exact name. It is what tells the tranny what position it is in. It is located on the drivers side middle of the transmission
post #6 of 32 (permalink) Old 01-16-2010, 07:38 AM
MLPS - Manual Level Position Sensor
http://forums.tccoa.com/showthread.php?t=124074
post #7 of 32 (permalink) Old 01-16-2010, 11:32 AM Thread Starter
I think its also called the Neutral Safety Switch. At least that is how I just found it on the Autozone site.
post #8 of 32 (permalink) Old 01-16-2010, 11:38 AM
SuperNewbie
supergordo's Avatar
The 2-3 accumulator could be stuck in it's bore.
1995 Cougar XR7 4.6
1997 Thunderbird LX 4.6
1977 Country Squire 460
1985 Capri RS 5.0, 5spd
1997 Thunderbird 4.6
1984 Capri RS 5.0,5spd
supergordo is offline
post #9 of 32 (permalink) Old 01-20-2010, 02:41 PM Thread Starter
Na, replaced those with new ones... but then again, that was the bad accumulator to begin with. Possible the walls got slightly wacked but they looked good when I did the J-Mod. You may have a point.
post #10 of 32 (permalink) Old 03-23-2010, 07:18 PM
crash00527's Avatar
Send a message via AIM to crash00527
torque converter shudder?
1995 40th. Ann. Supercoupe
1 of 5,167
Black ~ AOD ~ Moonroof ~ 82K
SCCOA Member #3093
CPL/0861/0844 USMC
Forward Observer/Fire Direction Center
Click below for Current PICS and MODS.
http://www.cardomain.com/ride/2466286
crash00527 is offline
post #11 of 32 (permalink) Old 03-23-2010, 07:52 PM
White lincoln... when you did the J mod and left the springs out you did bend the tabs out a little on the accumulator cover right? If not it can fall out and the piston can fall out of the bore with no spring.
FunktasticLucky is offline
post #12 of 32 (permalink) Old 03-23-2010, 08:45 PM Thread Starter
I think the first time I put the 2-3 cap back in, I bent the tabs a bit because when I put it back in this time, I had to gently tap it in (it would not just push in easily).
It runs fine now. I tested the oil level and it was only about a quart low. It shifts better now, more like it is supposed to. I narrowed the problem down to the MLPS. Today I put the tranny in 2nd, drove to about 30+mph and put it in drive and it did not want to go into 3rd and I had put it in neutral then back to drive. Other than that, it shifted flawlessly today while driving.
As for the torque convertor, ya, they are know to be crap, but it is okay. With the torque convertor shudder, that is more a 'shudder' from 2-3 and can be fixed with either using an additive like Lubegard or Mercon V. Mercon was designed with that issue in mind (shudder) as well as a lot of other issues.
Thanks everyone.
1995 Lincoln Town Car Signature Series - 200k!
1994 Mercoury Cougar XR7 - 150k and still going.
I've had too many other cars to mention...
post #13 of 32 (permalink) Old 03-24-2010, 03:56 PM
crash00527's Avatar
yikes....
1 of 5,167
SCCOA Member #3093
CPL/0861/0844 USMC
post #14 of 32 (permalink) Old 03-24-2010, 06:35 PM
Darrin's Avatar
That actually can't happen. I posted cutaway pictures of the accumulator bore in another thread about this and it is clear that you can darn near take the cap completely out and the piston won't fall out if you have the old style valve body with the 3rd stiffner plate.
Also, by design, the cap can be replaced into the bore fairly loosely as long as it is in the bore. I can speak with authority in telling you that the reason it is suggested that you bend the tabs is to keep the cap from falling out while you are doing this in the car with the transmission in a position that would allow the cap to fall out.
Darrin.
Darrin is offline
post #15 of 32 (permalink) Old 03-25-2010, 09:50 PM Thread Starter
BINGO!!!
Thanks Darrin for making that clear.
post #16 of 32 (permalink) Old 04-02-2010, 10:33 PM
I have a similar problem, except it won't go into 3rd gear at all. My car has been sitting for 2 years. I change my fluid abt 10000 mile b4 I quit driving. Now it jerks, bucks and stutter. I did a code reading and it says output speed sensor. Fyi, I never changed my fliud in my tc. Any advice would be greatly appricated
bhj1977 is offline
post #17 of 32 (permalink) Old 04-05-2010, 05:41 PM Thread Starter
Tranny rebuild?
DId you try some Merc V or Merc III with additive?
If it's not a simple fix, I'd say its time for a rebuild especially if you never changed the fluid.
DId you say you changed the fluid, filter and made sure you drained all areas of the tranny? I am not sure which car you are talking about.
post #18 of 32 (permalink) Old 04-05-2010, 05:52 PM
Output shaft speed sensor? Did you unplug it to try and override the speed limiter?
post #19 of 32 (permalink) Old 04-06-2010, 05:01 PM
crash00527's Avatar
i put some lucas tranny additive in mine. ran awesome for like a day. than went back to normal.
1 of 5,167
SCCOA Member #3093
CPL/0861/0844 USMC
post #20 of 32 (permalink) Old 11-03-2010, 03:54 PM
fenix's Avatar
Hey guys I'm new and I was reading this post and mi trans sometimes act weird like slip o not overdrive rigth I have a check engine light is p0720 what is output speed sensorinsufficient input so I replace the sensor in the talishaft transmission but still the same light and I'm running out in options will be great if you can giveme some tips thanks.
fenix is offline
post #21 of 32 (permalink) Old 11-03-2010, 03:59 PM
fenix's Avatar
fenix is offline
post #22 of 32 (permalink) Old 12-12-2010, 06:44 PM
CougarChaserXR7's Avatar
did you clear the code?
1995 Cougar Xr7 4.6
The never ending debate:
http://forums.tccoa.com/showthread.php?t=132847
CougarChaserXR7 is offline
post #23 of 32 (permalink) Old 12-12-2010, 07:00 PM
crash00527's Avatar
yea. whatever happened with that?
1 of 5,167
SCCOA Member #3093
CPL/0861/0844 USMC
post #24 of 32 (permalink) Old 12-14-2010, 08:51 PM
BUCK's Avatar
Lightbulb
My guess is misaligned MLPS.
BUCK is offline
post #25 of 32 (permalink) Old 12-15-2010, 02:01 PM Thread Starter
I think your right. Mine was acting up all the time and it turned out to be the MLPS and 2 quart low on fluid (my bad). I took it to AAMCO and they fixed it all and got it running real sweet for about $50. Worth it to me since I could not get the damn thing aligned right.
After that it has been driving like a Cougar should.
post #26 of 32 (permalink) Old 12-16-2010, 04:15 PM
wow... I'm suprised they didn't tell you it needed a rebuild... aamco is the WORST place EVAR!!!
post #27 of 32 (permalink) Old 12-17-2010, 12:04 AM
BUCK's Avatar
Question
damn sure the most expensive... I don't know about worst.
BUCK is offline
post #28 of 32 (permalink) Old 12-19-2010, 12:32 AM Thread Starter
wow... I'm surprised they didn't tell you it needed a rebuild... aamco is the WORST place EVAR!!!
They earned my trust when in Vegas on a trip in the Town Car and my tranny was acting up, I called them and they said bring it by. I sat and chatted with the guy that was stepping in for the manager and we kinda got to know each other. They don't charge to look at the tranny or the oil. They said the tranny looked good and what probably happened was the tranny got too hot coming through Hoover Damn. Anyway, it never acted up since then.
For the Cougar, the guy was straight up and honest with me. He drove a Cougar like mine so maybe we kinda bonded. Besides, I told him I did all the mods on the tranny and he did the same on his. So he probably knew I knew that it was not a tranny problem.
Needless to say, I understand your point cause I never trusted them from all the horror stories I heard, but they have proved to me that I can trust them. They gave me no **** about what I needed and what I expected.
Maybe its the way you approach them. Act like you know what your talking about and they won't try and shiest you.
post #29 of 32 (permalink) Old 12-19-2010, 12:50 AM
I worked with a guy who ran the desk at aamco and the things he did to people disgusted me to no end. I am glad I don't have to deal with it anymore.
I remember a few incidents. I watched a guy get charged almost $5000 for me to put a filter and solenoid (roughly $250 of parts) and some fluid on a toyota land cruiser. When I was all done the service writer came out and painted the transmission still in the vehicle. He sold the guy on a warranty service and everything else. I think anyone working on commision in this business is going to rip you off, guys who work flat rate or hourly just want to make a honest living.
post #30 of 32 (permalink) Old 12-19-2010, 02:05 AM
Yep. I was looking for someone to install my built transmission cuz i didn't have a lift to do it. Ended up calling the aamco in Asheville NC. Got the manager on the phone and he was like oh well where you getting transmission. I could build you one cheaper and better I'm sure. We ended up getting into. Huge argument over the phone because he kept trying to tell me there was nothing I could do tonmake these transmissions stronger than what they came from ford able to support. He kept trying to pressure me into a rebuild from him. He then told me there was no difference between any of the model years and when I brought up the mechanical diode one way clutch and things ford changed over the years he hung up on me. They are just out to screw you over with cheap ass rebuild and warranty and charge you 3500 bux. Screw that.
