Vibration/Shake coming out in the steering wheel - TCCoA Forums
post #1 of 20 (permalink) Old 02-08-2010, 05:22 PM Thread Starter
Floordford's Avatar
What is going on is that, as soon as my transmission shifts into 3rd and locks up it sends a shake through the body and makes the steering wheel vibrate. It gets better if i back off the throttle but in turn it gets worse when I load it up when its locked up.
I have replaces alot of things to try to hunt this down including:
Inner tie rods
Outer Tie rods
Tires
Harmonic damper
Mounts
Rims
Gears
Poly rack bushings
Steeda X2 ball joints
Poly A-arm bushings
I have a 4R70W in my 2000 Mustang GT. It has a J-mod, PI 3,500 converter, 3.73s, poly mounts and an aluminum DS.
2000 GT
Xcal2, FIPK2, Accufab 75mm, P/p upper, heads, long tubes, o/r-H pipes, Borla c/b, 3.73, PI 3,500stall, subframes, full Cobra brakes.
Show cars don't win races and race cars don't win shows.
Floordford is offline
post #2 of 20 (permalink) Old 02-08-2010, 09:31 PM
Stupid question but...
Have you checked to see if anything is loose?
post #3 of 20 (permalink) Old 02-08-2010, 10:05 PM
The_coop_08's Avatar
Send a message via AIM to The_coop_08
I would check your wheel bearings.
Silver 96 T-bird
Major Mods: Stage II PI head swap w/Stage II cams, Kooks headers, 2.5" exhaust with borla xr1, 9.5" Converter 3800 stall, Aluminum rear 3:73 gears, lots of suspension and bolt ons. 13" Cobra brakes, ss lines, lowered 1.6" on staggered saleens
Tim Barth tuned at MPH 274rwhp/298rwtq on 93
Compiling parts for Vortech build
95 SC 5 speed: bone stock for now
The_coop_08 is offline
post #4 of 20 (permalink) Old 02-08-2010, 10:07 PM
You're certain the problem isn't the torque converter? If you're getting vibration issues with lockup that's what I'd look into first. Fresh Merc-V and such?
post #5 of 20 (permalink) Old 02-09-2010, 11:11 AM Thread Starter
Floordford's Avatar
Everything up front is tight and is all installed correctly.
My wheels dont have that hushed grinding noise that comes with bad bearings. There is also no loose feel.
The torque converter is a Precision Industries Stallion multi disk, lock-up, 3,500stall. It only has about 10k miles on it. No track time and im the only owner. My fluid should be good, it was replaced 14k miles ago along with the filter. I could drain the converter and change the filter just to see.
2000 GT
post #6 of 20 (permalink) Old 03-23-2010, 07:12 PM
crash00527's Avatar
Send a message via AIM to crash00527
how about also just balancing your wheels lol happened to my friends once. his weight fell on one and the other was messed up.
1995 40th. Ann. Supercoupe
1 of 5,167
Black ~ AOD ~ Moonroof ~ 82K
SCCOA Member #3093
CPL/0861/0844 USMC
Forward Observer/Fire Direction Center
Click below for Current PICS and MODS.
http://www.cardomain.com/ride/2466286
crash00527 is offline
post #7 of 20 (permalink) Old 03-23-2010, 07:49 PM
my PI stallion is crap... the Clutch Plates rattle and it's all out of whack. My new dirty dog 4300 stall 9 inch billet should be here by the end of the week
FunktasticLucky is offline
post #8 of 20 (permalink) Old 03-24-2010, 08:34 AM Thread Starter
Floordford's Avatar
My wheels are freshly balanced and PI is one of the top companies out there. I have heard complaints about Dirty Dog. Plus my situation gets very noticeable after it locks up in 3rd. Im also wondering if it could be that 4R70W driveshaft yoke.
2000 GT
post #9 of 20 (permalink) Old 03-24-2010, 01:12 PM
Yeah PI's are freaking awesome. Their paper clutches and rattling plates are awesome. Mine slips for about 1000 rpm after the 1-2 shift. You can see it in the data logs. It tries to lock up then finally succeeds at 5300 rpm or so. I used a dirty dog converter for almost 2 years with no problems. What exactly have these complaints been?
Also to touch on th pi failure. I'm not the only one. There are a few posts around here that have pictures of these failures. Most send the converter to DirtyDog or circle D to have the clutches swapped out adding even more cost to an already over priced converter
post #10 of 20 (permalink) Old 03-24-2010, 03:56 PM
crash00527's Avatar
whats the site for PI?
1 of 5,167
SCCOA Member #3093
CPL/0861/0844 USMC
post #11 of 20 (permalink) Old 03-29-2010, 01:36 PM
if your talking about Garbage company's then YES P.I. is one of the TOP for sure.
1995 Lincoln Mark VIII "Grandmas Car"
400,480 miles *STOLEN 04-13-08*
98 Mark VIII LSC
STONE
STOCK
SLOW
NO
MODS
HERE
XLRVIII is offline
post #12 of 20 (permalink) Old 03-29-2010, 01:38 PM
I and 99% of the racers I know with automatics use Circle D.
they are second to NONE in the torque converter industry.
98 Mark VIII LSC
STONE
STOCK
SLOW
NO
MODS
HERE
XLRVIII is offline
post #13 of 20 (permalink) Old 03-29-2010, 01:39 PM
Awesome!!!
lolz
98 Mark VIII LSC
STONE
STOCK
SLOW
NO
MODS
HERE
XLRVIII is offline
post #14 of 20 (permalink) Old 03-29-2010, 05:39 PM
crash00527's Avatar
That's pretty funny
1 of 5,167
SCCOA Member #3093
CPL/0861/0844 USMC
post #15 of 20 (permalink) Old 03-29-2010, 10:02 PM Thread Starter
Floordford's Avatar
What are you in second grade? It may not be some $1200 converter but of the tons of research ive done ive heard of very few complaints verses many guys that love them. They are built solid and are very good quality. My Precision Industries Stallion 3,500 Multi disk lock up hasn't given me any trouble.
2000 GT
post #16 of 20 (permalink) Old 03-29-2010, 10:33 PM
I hate to jump in cause I have no experience with either PI's, DD's, or anybody elses performance torque converter for that matter, but that being said...
Did you not start this thread complaining about a lot of vehicle shutter when the converter tries / does lock up? I'm sorry, you didn't say it happens during lock-up, but you DID say it happens when it shifts into 3rd and the converter locks up?!? Wait a minute...
So now you have a few members bad-mouthing PI converters and blaming it for your shutter problems. You asked for everyone's advice and just plain don't like what they're telling you because you think everyone here is biased toward DirtyDog's TC's. Maybe they are a little, but that's only because of SO MANY happy customers of his here ... maybe? I'm just saying...
Maybe the responses you got weren't very delicate or gentle, but at least they were honest. There's no need to get so defensive or upset.
post #17 of 20 (permalink) Old 03-30-2010, 08:35 AM
for the record, I'm not biased to Dirtyd0g converters...
I've had several friends that had bad experiences with PI converters, but they had vehicles that were actually making power, so they needed to "STEP UP" and get a Circle D.
If a PI converter wont stand up to a 250RWHP Tbird or mustang, then I think that is really ALL that needs to be said.
IMHO putting a PI converter in a car is a waste of transmission fluid.
I agree with Netkeym, it's likely the PI converter with its well known shudder issues.
98 Mark VIII LSC
STONE
STOCK
SLOW
NO
MODS
HERE
XLRVIII is offline
post #18 of 20 (permalink) Old 03-30-2010, 11:01 AM
CATALYST916's Avatar
sure sounds like your tc. how long have you had it in? and how long have you had the problem?
CATALYST916 is offline
post #19 of 20 (permalink) Old 03-30-2010, 04:53 PM Thread Starter
Floordford's Avatar
Hard to say. I know ive had it in for over 12k mi. And if i remember its always done it. I just thought it was part of not having my lock up shifted to a higher speed. Its still on the stock lock up program. 22mph or so with a 8-10 second unlock delay after hitting the brake.
2000 GT
post #20 of 20 (permalink) Old 04-07-2010, 02:01 PM Thread Starter
Floordford's Avatar
Ok, an update. I ended up curing 95% of the problem by taking the shift firmness down to -25%. That is an adjustment from +25%. Then I added 2mph to the shift of 1-2, 2-3, 3-4. It was at stock shift speed.
2000 GT
