97 Mark VIII tranny in a 95 Cougar? - TCCoA Forums
post #1 of 6 (permalink) Old 02-20-2010, 05:12 PM Thread Starter
Black_Cat's Avatar
So will a lincoln mark VIII tranny fit in my 95 cougar 4.6? the mark VIII had the dohc 4.6 I know it will fit physically, but is it worth getting? Will it work?
2011 BMW X5 35i Premium Package
2009 BMW 535i ///M Sport Package
2008 BMW 535i Premium Sport Package
Black_Cat is offline
post #2 of 6 (permalink) Old 02-20-2010, 05:21 PM
chris g's Avatar
Send a message via Yahoo to chris g
I was curious about that myself i got a 95 bird..
COLD AIR INTAKE, MN12 PERFORMANCE FRONT SUSPENSION KIT, SILVER PAINTED AVS WINDOW GUARDS, SILVER PAINTED DASH PANELS, 28% MIRROR TINTED WINDOWS, SUSPENSION TECHNIQUES 2'' DROP, TRUE BENDS CUSTOM 2.5'' TRUE DUAL EXHAUST. 2nd generation SC wheels.
chris g is offline
post #3 of 6 (permalink) Old 02-20-2010, 08:48 PM
decipha's Avatar
i don't see why not as long as they are both 4.6s it should work, the 3.8 v6 4r70w has a different bellhousing
the shift linkage may be setup different so that MAY need to be adjusted, can't say for certain because i've never owned a 4r70w just did a few swaps here and there for friends
keep in mind the torque converter clutch solenoid for the 98+ 4r70w's have a different impedance so if you get one from a newer 98+ engine you'll need to swap the tcc else you'll fry your ecu
O&E Speed Shop - 2333 Aberdeen St. Kenner, LA
EFI Calibrator - decipha @ EFIDynoTuning
http://www.efidynotuning.com/tune.htm
decipha is offline
post #4 of 6 (permalink) Old 02-20-2010, 10:33 PM
Year? 93-95 are a direct swap, 96-98 you need to open it up and swap the tcc solenoid.
post #5 of 6 (permalink) Old 02-20-2010, 11:52 PM Thread Starter
Black_Cat's Avatar
well i need something to put in it's place because there is fluid all over my rear diff and transmission. so i am taking everything off the car. i did get to drive her for 10 minutes in first gear earlier today though
post #6 of 6 (permalink) Old 02-21-2010, 08:02 AM
Dusty's Avatar
Besides the tcc solenoid you need to use a MLPS from your trans or get a new one for a 95 Tbird.
1995 PI Tbird
1998 TA Vert
2004 Buick Regal GS
2000 Honda ST1100
1990 Mazda RX-7 2+2
Dusty is offline
