Is my trans slipping? - TCCoA Forums
post #1 of 5 (permalink) Old 02-26-2010, 05:58 PM Thread Starter
kev0's Avatar
Question Is my trans slipping?
I'm relatively new and I haven't experienced a bad transmission before. Sometimes my engine gets loud when switching from 1st to 2nd. The Tachometer will usually read in the 2.5 to 3 range when this happens. Is my trans slipping? Can I get the transmission fluid flushed to help the problem? Or is there even a problem? Any suggestions would help. Thanks in advanced! -Kevin
1995 Thunderbird LX V8 (Zapdos)
-kev0
kev0 is offline
post #2 of 5 (permalink) Old 02-26-2010, 06:08 PM
Loud as in the RPMs flare up? If so then it sounds like slippage. If it hasn't been done within the last 30k miles, you should completely drain and refill the trans and torque converter. Do NOT attempt any kind of flush. That will cause more harm than good. If the fluid comes out dark and fullof friction material, your trans is toast. If not, put a new filter and refill it with Mercon V and only Mercon V.
post #3 of 5 (permalink) Old 02-26-2010, 09:48 PM Thread Starter
kev0's Avatar
I was afraid of that. I will take it to the shop this weekend and get it checked out. Seeing as I just bought it and it didn't start doing it until yesterday I'm hoping it can be fixed without replacing or rebuilding the transmission. Thanks man.
-kev0
kev0 is offline
post #4 of 5 (permalink) Old 03-01-2010, 09:39 PM Thread Starter
kev0's Avatar
I appreciate whoever moved this for me. I didn't know where is was supposed to go. I found out I just have a leak in my transmission. Its only going to cost me $200 to fix it. Thanks alot guys!
-kev0
kev0 is offline
post #5 of 5 (permalink) Old 03-07-2010, 12:05 PM
crash00527's Avatar
Send a message via AIM to crash00527
wow thats a nice and cheap fix. i need to rebuild my tranny. 1-2 gears are grinding
1995 40th. Ann. Supercoupe
1 of 5,167
Black ~ AOD ~ Moonroof ~ 82K
SCCOA Member #3093
CPL/0861/0844 USMC
Forward Observer/Fire Direction Center
Click below for Current PICS and MODS.
http://www.cardomain.com/ride/2466286
crash00527 is offline
