j-mod roblum - TCCoA Forums
post #1 of 8 (permalink) Old 03-07-2010, 01:11 PM Thread Starter
j-mod roblum
i just did the j-mod to my car and now it has no gears it will go into all of them just wont move only one it will move in is 1st and the what ever gear i put it in it will go forword even if it's reverse or n what dod i do wrong
dmiller is offline
post #2 of 8 (permalink) Old 03-07-2010, 01:14 PM
Make sure it has enough fluid in the trans for starters
post #3 of 8 (permalink) Old 03-07-2010, 03:11 PM
U missed the manual shift lever linkage pm I'll give u my number and explain
Robert
86 bird vortech s trim
10.75 @128.38
95 bird - Vortech t trim
1/8 [email protected]
10.11 @ 139.19 best mph
RobertP is offline
post #4 of 8 (permalink) Old 03-07-2010, 05:19 PM
Robert
Yup, what he said. I made that mistake once too.
MadMikeyL is online now
post #5 of 8 (permalink) Old 03-07-2010, 05:32 PM Thread Starter
shift lever linkage is that the piston thing when i first put it back together i had only 1st so i took it apart now i only have reverse and the shifter wont go into drive or any gear lower
dmiller is offline
post #6 of 8 (permalink) Old 03-07-2010, 05:43 PM
Give me your phone number I'll explain it to you
10.75 @128.38
RobertP is offline
post #7 of 8 (permalink) Old 03-08-2010, 09:23 AM Thread Starter
608-4980413 i get off work at 4
dmiller is offline
post #8 of 8 (permalink) Old 03-09-2010, 09:32 PM
BUCK's Avatar
http://memimage.cardomain.com/ride_i...021_medium.jpg
& do more research at http://www.cardomain.com/id/BlackIceLSC
BTW with patience you can siphon a buncha your brand new Merc V up the Dip Stick tube with the $8 Marine Pump fm Wal Mart - If you already don't have the reusable Motorcraft pan gasket then get one because the Felt Aftermarket job is a one shot deal = PERIOD.
BUCK is offline
