Well the Transmission finally blew up last night... Have questions for the experts - TCCoA Forums
post #1 of 5 (permalink) Old 03-13-2010, 11:40 AM Thread Starter
Dan Gray's Avatar
So its time to upgrade!!!
Now i have a few questions for you transmission guru's!!
I own a 94 t-bird LX with the 4.6L and im assuming it has the old AODE. I do drive the car hard and im pretty sure my one way clutch blew up as when it went for the 1-2 shift last night it just went bang and reved up. I let off and it engaged 3rd gear after a few seconds and then when i was cruising along at 50mph it just went back into second by itself and that was it. I only have 2nd gear now. first, third, and OD just rev up like in neutral. And when you put it into reverse it feels like the transmission is fighting itself like a trans brake!! hehe And when you put it in neutral the car is still locked, i cant even roll it. So i would say she is DONE!
Now i would like to upgrade to the 4r70w and i was reading all the articles about doing the swap and it looks fairly easy. And i know alot of you on this site have done this swap. Is it really that easy?? I want to upgrade the torque convertor to a bit of a higher stall anyways so thats no big deal but correct me if im wrong but is it only the gear selector sensor, re-arranging the pins in the main connector, and changing the size of the yoke the only things i will need to change to make it work??
Dan
Gray Performance Motorsports
1994 Thunderbird 4.6L Stock 3900LBS [email protected]
Rear Gear Swap 4.10 [email protected]
PI Head swap with cams and intake [email protected]
1989 Mustang LX 331 T-Trim [email protected]
[email protected], 675FT LB @5700RPM
1983 F-250 N/A 460CU. IN. Stock short block, edelbrock heads, cam, T-56 Magnum, stock Dana rear end [email protected]
Dan Gray is offline
post #2 of 5 (permalink) Old 03-13-2010, 11:43 AM
I don't really have any insights to your questions, but you already have a 4R70W in your car. AODE never came on T-birds or Cougars, only the AOD - and that was until '93.
post #3 of 5 (permalink) Old 03-15-2010, 09:34 PM
Darrin's Avatar
The above is definitely correct. You already have a 4R70W. Upgrading to a newer one isn't too difficult. Make sure you get one that has the same length output shaft as some had a 1in longer shaft and housing.
Unless it comes from a Bird, Cougar or Mark VIII then you will have to address the output shaft having 8 teeth instead of the 7 that is on your transmission.As long as you haven't stepped up to 3.73 or better gears then you can address that with a speedo gear swap.
No need to mess with the yoke obviously since you already have the right one.
For a slightly higher stall speed on the converter you can get a factory 11.25in converter from a Mustang, Mark VIII, Crown Vic, Grand Marquis or Marauder. You will also need the matching flexplate to do that.
No truck transmissions and stay away from anything 03 and newer.
Easy swap as long as you do your homework.
Darrin
Darrin is offline
post #4 of 5 (permalink) Old 03-16-2010, 12:06 AM Thread Starter
Dan Gray's Avatar
Thanks guys, ya i have done some more homework and have figured out what needs to be changed or transfered over. And i have managed to come up with a transmission out of a 01 mustang V8. I am sending it in to my local shop to have it gone through!
Dan
Dan Gray is offline
post #5 of 5 (permalink) Old 03-21-2010, 11:49 PM Thread Starter
Dan Gray's Avatar
well i swapped the transmission today and it was super easy and everything went off without a hitch! Thanks again
Dan
Dan Gray is offline
