Wont shift when tranny is warm - TCCoA Forums
post #1 of 22 (permalink) Old 03-16-2010, 01:11 PM Thread Starter
Unreal95Bird's Avatar
I have a 95 tbird and When the tranny is cold it will shift 1st-4th but when it gets warmed up it only shifts 1st and 2nd. I changed the solenoid, filter, gasket, and fluid and now it does this and leaks. Anyone know whats up? I think i can fix the leak with tightening the pan some more but im more worried about the shifting problem.
Unreal95Bird is offline
post #2 of 22 (permalink) Old 03-16-2010, 02:12 PM
question first. did it shift ok (1st through 4th) cold and warm before you changed the parts and fluid???
My Lug Nuts Require More Torque Than Your Honda Makes
Tbird64 is offline
post #3 of 22 (permalink) Old 03-16-2010, 02:44 PM Thread Starter
No before it only shifted in 2nd and 3rd. Thats why i changed the solenoid pack. Now it work only when its cold and when it gets warm it goes into neutral instead or 3rd or OD.
post #4 of 22 (permalink) Old 03-16-2010, 06:02 PM Thread Starter
Anyone?
post #5 of 22 (permalink) Old 03-16-2010, 11:18 PM
Patience
Patience, young Jedi. Most people use computers as the tool they are and most likely haven't seen your question yet. The suggestions with come, they just take longer than 24 hours - this isn't cha-cha or KGB.....lol
Personally, I don't have any good ideas or I would have already told you.
post #6 of 22 (permalink) Old 03-17-2010, 12:08 AM Thread Starter
Lol ok then thanks though
post #7 of 22 (permalink) Old 03-17-2010, 01:22 AM
dDUBb's Avatar
Have you been reading through the Transmissions 101 article ??
Check the Common Problems, and Diagnosing Transmissions Problems sections of the 101 article.
Im thinking ... failing Intermediate one way clutch based on what you have described.
dDUBb is offline
post #8 of 22 (permalink) Old 03-17-2010, 03:13 PM Thread Starter
Alright got under the car today and fixed the leak. Then i took it for a 10 in drive and everything was working perfect. When the car warmed up and i accelerated harder, when in OD it just went to neutral. This time i kept 3rd though. And also is there too much oil in when i take out the dipstick and the fluid goes half way up the dipstick? Thanks
post #9 of 22 (permalink) Old 03-17-2010, 03:18 PM
dDUBb's Avatar
Way too much .. it needs to be readable on the little indicator on the bottom of the dipstick.
dDUBb is offline
post #10 of 22 (permalink) Old 03-17-2010, 03:22 PM
Fluid expands when warm. so if its already overfilled then you get it warm it is even farther over filled.
Tbird64 is offline
post #11 of 22 (permalink) Old 03-17-2010, 03:23 PM Thread Starter
How many is suppose to be in the pan? I put in 8 when i changed the solenoid. Isnt that right?
post #12 of 22 (permalink) Old 03-17-2010, 03:30 PM Thread Starter
So you think that could be my problem?
post #13 of 22 (permalink) Old 03-17-2010, 03:35 PM
When a transmission is overfilled the oil gets aerated ( full of bubbles) and can cause erratic shifts. Could this be your problem? yes. am i 100 % sure? no. is their a bunch of bubble's in the fluid when you check it?
Tbird64 is offline
post #14 of 22 (permalink) Old 03-17-2010, 03:41 PM Thread Starter
Well i just checked and there were no bubbles on the dipstick but fluid was on it all the way up to the middle. Would I have to drain all the fluid and get more or can i reuse it? Cause its pretty expensive for mercon v. Or what do you recommend i do about it?
post #15 of 22 (permalink) Old 03-17-2010, 04:53 PM
dDUBb's Avatar
Did you drain the TC also ? Or just drop the pan and fill it up with 8 quarts ?
Do you still have the stock 95 pan, or the 96 + ?
dDUBb is offline
post #16 of 22 (permalink) Old 03-17-2010, 05:59 PM Thread Starter
No i didnt drain the TC, and i did just drop the pan and add 8 quarts. I also have the 95 pan and flter. I just drained most of the extra tranny fluid and i have the same problem. I think it needs a rebuild or replace. I dont have the money for either
post #17 of 22 (permalink) Old 03-18-2010, 11:09 AM
So cold it goes 1-2-3-4, but warm is goes 1-2- and then NEUTRAL....if that is the case, that is bad, and a sign of direct clutch death.
www.Silverfoxtrans.com
www.clickclickracing.com
SilverFox is offline
post #18 of 22 (permalink) Old 03-18-2010, 11:23 AM
SuperNewbie
supergordo's Avatar
Agreed.
What did the fluid look like when you first dropped the pan? Was there a bunch of crap built up on the magnet?
Maybe go find yourself a good used tans from the junkyard.
1995 Cougar XR7 4.6
1997 Thunderbird LX 4.6
1977 Country Squire 460
1985 Capri RS 5.0, 5spd
1997 Thunderbird 4.6
1984 Capri RS 5.0,5spd
supergordo is offline
post #19 of 22 (permalink) Old 03-18-2010, 02:52 PM Thread Starter
First time i dropped it the magnet had alot of black build up on it. So do you think that i should just get a used 95 tranny for 250 at my local junkyard? What would be the best option?
post #20 of 22 (permalink) Old 03-18-2010, 03:50 PM
dDUBb's Avatar
If you plan on keeping the car - buy a good transmission or have one built up.
If you dont care and plan on getting rid of the car .. junkyard transmission might work for a little while.
dDUBb is offline
post #21 of 22 (permalink) Old 03-18-2010, 06:00 PM
Having one built up is def. the best way to go if your gonna keep it because their is no such thing as a "good" used 4R70. IMO if its got more than 60K on a stock 4R70 its gonna need a rebuild in the near future anyways
Tbird64 is offline
post #22 of 22 (permalink) Old 03-18-2010, 06:20 PM Thread Starter
Well i just bought the car and dont really have much money cause i recently lost my job. Im thinking of just selling this bird once the Tranny is fixed and getting a 96 or 97 so i can do mods like PI intake and stuff. Lol but thanks everyone that helped me.
