95 tbird tranny - TCCoA Forums
post #1 of 7 (permalink) Old 03-29-2010, 02:13 PM Thread Starter
durbinXR7's Avatar
95 tbird tranny
I recently cleaned out the egr ports on the intake manifold, before I took everything apart the tranny shifted fine but now that everything is put back together, the tranny won't shift into gears unless I manually shift them, I have a different tps on the car but it's not plugged in cause I need to get a new pigtail, was just wondering why my car is doin this or atleast what to look for, thanks
95 thunderbird LX - super coupe sway bars, front shock brace,custom exhaust, auxiliary trans cooler, cold air intake,180 degree thermostat, RSTB, custom front grille, HID conversion,18X9 Bullits,PBR front dual piston calipers,80MM MAF,eibachs 1.5" lowering springs, bilstein rear shocks,tokico front shocks, rear drum to disc brake swap,tinted windows,all new sound system
durbinXR7 is offline
post #2 of 7 (permalink) Old 03-29-2010, 02:20 PM
The fact that you have the TPS unplugged is probably your problem.
post #3 of 7 (permalink) Old 03-29-2010, 02:28 PM
The_coop_08's Avatar
Send a message via AIM to The_coop_08
X2
Silver 96 T-bird
Major Mods: Stage II PI head swap w/Stage II cams, Kooks headers, 2.5" exhaust with borla xr1, 9.5" Converter 3800 stall, Aluminum rear 3:73 gears, lots of suspension and bolt ons. 13" Cobra brakes, ss lines, lowered 1.6" on staggered saleens
Tim Barth tuned at MPH 274rwhp/298rwtq on 93
Compiling parts for Vortech build
95 SC 5 speed: bone stock for now
The_coop_08 is offline
post #4 of 7 (permalink) Old 03-30-2010, 12:59 AM Thread Starter
durbinXR7's Avatar
ok thats what I thought,but wasnt exactlly sure,thanks for the input guys,really appreciate it
post #5 of 7 (permalink) Old 03-30-2010, 11:39 PM Thread Starter
durbinXR7's Avatar
one other thing,this isnt about the tranny but i didnt want to make another thread,when im driving the car and its at WOT,the RPM's dont shut up or anything,it kind of gags and acts like its choking,the only codes im throwing are tps input low,and maf input low,can someone help me out
post #6 of 7 (permalink) Old 03-31-2010, 07:41 AM
A bad TPS would cause this as well.
post #7 of 7 (permalink) Old 03-31-2010, 11:19 PM Thread Starter
durbinXR7's Avatar
Alright got the pigtail for the tps and it runs great now, thanks
