emergency, need answers now - TCCoA Forums
post #1 of 6 (permalink) Old 04-09-2010, 10:51 PM Thread Starter
danalba's Avatar
Exclamation emergency, need answers now
I know this is he wrong spot but I figured it would get more attention
here. my 97 birds tranny is acting up. it's auto and when I put it into gear a high pitched tone goes off and it kinda sputters, if I rev it while it's in gear it jumps into gear with a jolt. it seems to drive fine once it jumps into gear but fifty fifty when I slow down it either has to jump into gear again once I accelerate or it works fine. what's wrong?? is it a sensor?? I'm in Orlando on vacation and supposed to be driving back to Michigan? helppp
MAC CAI/02 STANG MAF/SCT CHIP TUNED BY LONNIE
EIBACH 1.5 LOWERING SPRINGS- BILSTEIN GAS SHOCKS
90 SUPERCOUPE SIDE SKIRTS/REAR
18x9-FRONT: 245 REAR: 275
PI intake/PI cams
355 trac lok
new tune for swapped parts (93 oct)
no longer the owner.... but its still my child its just released into the world....
danalba is offline
post #2 of 6 (permalink) Old 04-10-2010, 12:43 AM
Nitemare's Avatar
My not too expert first thought is the EPC solenoid.
Needs more stall.
Nitemare is offline
post #3 of 6 (permalink) Old 04-10-2010, 12:49 AM
RESET's Avatar
My non expert first thought is... did you check the fluid level? When you checked it, did it look burnt?
RESET is offline
post #4 of 6 (permalink) Old 04-10-2010, 09:10 AM
Cool
Yea, check the fluid. Preferably after it's warmed up, and while in idle and foot on your brake, run through reverse, neutral and drive a couple of times. If you check it cold, it still should at least be at the "COLD" fill level. If it's dark or smells get it checked.
Uncaged 94 is offline
post #5 of 6 (permalink) Old 04-12-2010, 08:18 AM
I would take it to a trans shop, but it sounds electronic in nature - MLPS probably.
Never heard of an issue like this.
www.Silverfoxtrans.com
www.clickclickracing.com
SilverFox is offline
post #6 of 6 (permalink) Old 04-13-2010, 04:20 PM Thread Starter
danalba's Avatar
took it to the trans shop. turns out it was pretty much toast. know idea how didnt beat on it or even drive it hardly after this started. no overheatting or anything. anyways guy said TC went and through pieces of the TC into the trans pump and some plates fuzed together from overheating which i guess im not sure how since i didnt have any overheating. anyways. guy is charging me $2244 to fix it. i feel thats REAL steep but i cant do anything about it. 1200 miles away from home.
PI intake/PI cams
355 trac lok
danalba is offline
