WTF is going on? - TCCoA Forums
post #1 of 10 (permalink) Old 04-12-2010, 06:56 PM Thread Starter
TonyD.'s Avatar
WTF is going on?
I dont know a whole lot about transmissions. When i had the motor out, i looked at the transmission. It looked fairly new. The front pump was nice and shiny, no leaks from anywhere. I drained my fluid and dropped the pan about 10,000 miles ago. The old fluid was red, not burnt at all. So Ive been under the impression thats its a good, newer trans. The other night, It started to slip. The fluid level is perfect, and the newer fluid is good. But what puzzled me was, it doesnt slip from 1-2 manual shifting, but it will slip from 1-2, 2-3, and 3-4 in drive. What are the odds of that? Im thinking one of the solenoids is on its way out, but like i said earlier, im not a transmission man. Can anyone help me out?
ʎɐqǝ uo pɹɐoqʎǝʞ ɐ ʎnq ı ǝɯıʇ ʇsɐן ǝɥʇ sı sıɥʇ
TonyD. is offline
post #2 of 10 (permalink) Old 04-12-2010, 07:53 PM
How many miles are on it? You've probably got close to 200K or more on it now.
Time for a rebuild...
post #3 of 10 (permalink) Old 04-12-2010, 07:55 PM Thread Starter
TonyD.'s Avatar
about 120000
TonyD. is offline
post #4 of 10 (permalink) Old 04-12-2010, 07:59 PM
Hummm? Not as high as i thought it would be.
J-mod it and get an auxillary trans cooler. It should get you to 200K+ without any problem. It wouldn't hurt to replace and upgrade the TC also.
post #5 of 10 (permalink) Old 04-12-2010, 08:02 PM Thread Starter
TonyD.'s Avatar
yea, that definately needs to go. it has the shudder problem. could that also be a problem if it gets real bad? when i let off the gas, it gets stuck at 1500 rpms and doesnt drop for about 5 seconds.
TonyD. is offline
post #6 of 10 (permalink) Old 04-12-2010, 08:02 PM
120,000 for a 95 transmission is good mileage. I wouldn't waste one red cent on it. Buy a late model unit and adapt it.
post #7 of 10 (permalink) Old 04-12-2010, 08:08 PM Thread Starter
TonyD.'s Avatar
i was thinkin 01-04 mustang trans. what would i need to make it work?
TonyD. is offline
post #8 of 10 (permalink) Old 04-12-2010, 08:21 PM
Send a message via AIM to LoadedButane Send a message via Yahoo to LoadedButane
I have over 200k on my original 95 transmission and it still works fine. I am still going to upgrade it so when I do the mods I have planned it will last.
Geoff
1995 Mercury Cougar
~Mark VIII Trans with jmod + converter, 255lph fuel pump
~heads, cams, and intake in the distant future or when I break something
LoadedButane is offline
post #9 of 10 (permalink) Old 04-12-2010, 11:50 PM
You can't go later than 2002 without swapping the output shaft.
post #10 of 10 (permalink) Old 04-13-2010, 01:19 PM
When you find the trans you want to use I can tell you what you need to adapt to make it work. I prefer to swap the output shafts inside the transmissions and use really late model cores. However what is a 45 minute project to me isn't so quick for others.
