J-modded slipping out of gear on HARD 1-2 Shift - TCCoA Forums
post #1 of 13 (permalink) Old 04-14-2010, 09:48 PM Thread Starter
greencurse's Avatar
I really enjoy my jmodded trans, just as much as the next guy.
However now on a hard launch and the consequent 1-2 shift the car slips out of all gears puts no power down and the engine revs to the heavens.
Im thinking that I might just rebuild it but I dont want to go through all the trouble if it's something smaller.
Car has ~175K on the original trans, fluid is clean and full, J-mod has two springs on the new design 1-2 accumulator and 1 on the 2-3.
1997 Thunderbird LX, 4.6L, Performance White.
3.27 TL, 300hp J-Mod, Mid-Mount Magnaflow w/2.25" True Duals to 3" Magnaflow 15* Slash Cut Tips, PI Intake,
FR500 Steering Wheel, FRPP Wires, 180* T-Stat, 22C Plugs, Cobra Vert Rears, RSTB, SC "L" Braces. 175k and still flying!
greencurse is offline
post #2 of 13 (permalink) Old 04-14-2010, 09:56 PM
Car has ~175K on the original trans, fluid is clean and full, J-mod has one spring on the new design 1-2 accumulator and 2 on the 2-3.
You put 1 spring on the 1-2 accumulator piston and 2 springs on the 2-3 accumulator piston?
post #3 of 13 (permalink) Old 04-14-2010, 09:58 PM
RESET's Avatar
It should be 1 or 2 springs on the 1-2 and none on the 2-3.
RESET is offline
post #4 of 13 (permalink) Old 04-14-2010, 09:59 PM Thread Starter
greencurse's Avatar
Unless I got it backwards... its been fine for three years its just recently been acting up
post #5 of 13 (permalink) Old 04-14-2010, 10:08 PM
Oh, you failed to mention you did the j-mod 3 years ago. Yeh, if you put 1 and 2 springs back in, it had to be 2 springs one 1-2 (one on top, one on bottom), and 1 spring on 2-3 (one on top).
Regardless, back to your original problem. I had that problem when I first did my j-mod except it didn't happen at WOT, but at 1/2 to 3/4 throttle. The car would act like it shifted to 2nd for just an instant, then pop out like it went to neutral. I just kind of ignored it because it didn't happen all the time and it seemed to have went away by itself.
In your case (as I was told could be my problem by some here), the lack of a mechanical diode was known to be weak area in pre-98 transmissions. Sounds like that is your problem, but I'm no expert by any means.
You'll hear from some more experienced here shortly, I'm sure. Good luck!
post #6 of 13 (permalink) Old 04-14-2010, 11:03 PM
One way clutch Is gone will it go into the limiter on the 1-2 if u don't let out of it?
86 bird vortech s trim
10.75 @128.38
95 bird - Vortech t trim
1/8 [email protected]
10.11 @ 139.19 best mph
RobertP is offline
post #7 of 13 (permalink) Old 04-14-2010, 11:09 PM
95xbird's Avatar
Yep Clutch = Gone. With that many miles it might be time for a rebuild.
Its slow, Really.
LS1 KILLER
1995 svo Tbird. R.I.P.
95xbird is offline
post #8 of 13 (permalink) Old 04-15-2010, 03:09 AM Thread Starter
greencurse's Avatar
damn skippy. thats the ticket... Good thing I have a week off coming up soon.
post #9 of 13 (permalink) Old 04-15-2010, 03:17 AM Thread Starter
greencurse's Avatar
also while i have everyones attention, what brand should I go with for the rebuild kit? and what other parts besides the converter will i need not included in a kit
post #10 of 13 (permalink) Old 04-15-2010, 09:12 AM
I use transtar kits, either a new overdrive band or the heavyduty one if it's just a basic rebuild
Robert
10.75 @128.38
RobertP is offline
post #11 of 13 (permalink) Old 04-15-2010, 09:37 AM
Instead of a rebuild i bet you could find a cheap low mile 4R from a junkyard.
2004 Subaru OBW MT (95k) - "The lesmobile" slow, but capable
1987 Merkur XR4Ti (49k) - fixing electrical issues & getting it running right... then mods
1993 Lincoln Mark VIII (129k) SOLD
wood_e is offline
post #12 of 13 (permalink) Old 04-15-2010, 12:40 PM Thread Starter
greencurse's Avatar
I think i can do it my self and just get a $200 kit, I just dont want to pull it or put it back in, but I will to save $1100-$1500. I guess im going to do a marauder converter and mark viii flexplate while its out.
post #13 of 13 (permalink) Old 05-01-2010, 10:03 AM
seawalkersee's Avatar
Did you ever get a converter for this? I have one for a Marauder if you are interested.
SWS
seawalkersee is offline
