Shifter will move from park without pressing the brake or even turning the engine on. - TCCoA Forums
post #1 of 7 (permalink) Old 04-20-2010, 05:19 AM Thread Starter
kev0's Avatar
I learned a very scary fact about my car yesterday afternoon. I had just picked up my 10 year old cousin from school and needed to run by the grocery store before returning home. My cousin did not want to come inside with me, so I cracked the windows and left him in the car. When I come back outside I am shocked to find my car in the grass right behind the spot I left it in. My cousin was behind my bird trying to push it back where I left it! Hilarious I know, but dangerous never the less. So after I move the car back into an appropriate spot, I have to ask him how this happened. He said that he was sitting in the passenger seat and simply pressed the button on the shifter and moved it down into reverse. I checked and he was not lying. I am able to shift into any gear without even having to start the car. No brake petal or anything like that either. So the question is, how do I fix this? I mean I know not to leave him in the car anymore, but the whole shifter moving without the brake petal thing. I'm not sure if this has anything to do with it, but my shifter does not light up at all either. It is a 1995 Ford Thunderbird with a 4.6 v8 and an automatic transmission. Thanks in advanced! -Kevin
1995 Thunderbird LX V8 (Zapdos)
-kev0
kev0 is offline
post #2 of 7 (permalink) Old 04-20-2010, 05:58 AM
I can't help you with your issue, but it is always recommended to set your parking/emergency brake whenever you park the car. If your car is tapped in a wreck, and it breaks the tab in the transmission, it can become mobile going who knows where. And youngin's can't get the car to move as easily.
And if you have rear disc brakes, setting the parking brake is what adjusts them.
I'm glad it only ended up in the grass, it could have been considerably worse!!
69 F100 LWB w/460 Engine
post #3 of 7 (permalink) Old 04-20-2010, 07:09 AM
miller1995's Avatar
The shift interlock cable that is either disconected or broken.
-Miller
SOLDWhite '03 Crown Vic P71
SOLD2006 Mazdaspeed6
SOLD1998 Escort ZX2
RIP My Black 95 LX 4.6
miller1995 is offline
post #4 of 7 (permalink) Old 04-20-2010, 05:35 PM
silverbird97's Avatar
I dont have kids or anything but I kinda like being able to just put it in gear. Great for when you back in a spot. Just throw it in gear and hit the gas.
97 T-bird Silver 4.6
If it aint one thing its another.
silverbird97 is offline
post #5 of 7 (permalink) Old 04-20-2010, 09:07 PM
Awaiting E-Mail Confirmation
tinman_72's Avatar
-Miller
It has been a while since I had my column apart but I think that a broken cable would not allow the shifter out of park in any case; the cable is what disengages the lock.
I would take the covers off the column and grease the cable up, it is probably sticking.
tinman_72 is offline
post #6 of 7 (permalink) Old 04-21-2010, 10:39 PM Thread Starter
kev0's Avatar
I'll have to take it apart this weekend and check it out. Thanks guys!
-kev0
kev0 is offline
post #7 of 7 (permalink) Old 04-22-2010, 02:32 AM
A broken cable would allow it to freely release at any time. The way the interlock works is then when you press the shifter button, the cable is pulled. The steering column mechanically locks the end of the cable when the ignition is in the OFF or ACC position and is mechanically released otherwise (this is why turning the key to just before ON lets you press the button). There is a solenoid that is then energized to lock the cable in place when the ignition is ON, and the cable is only released when the brake pedal is held, which de-energizes the solenoid and releases the cable. So a broken cable, disconnected/faulty solenoid, broken steering column, or broken/disconnected shifter lock linkage will cause the described problem.
