Trans swap problems. - TCCoA Forums
post #1 of 8 (permalink) Old 04-20-2010, 12:14 PM Thread Starter
I have a 95 cougar that had a 99 grand marquis trans swapped in about 2 years ago. I have since fried that trans and have now swapped in a 96 t-bird trans.
I have swapped over the valve body that has been j-modded, 3500 stall torque converter and all the solenoids and parts to the upgraded connections.
The only gear that I have is 1st gear. The rpms drop in all gears but 2nd and the car only egages in first. I have been trying figure it out for the last couple of days with no success. I was hoping someone may be able to point in the right direction on what to check.
Thanks Rick.
PI head and intake swap, J modded 99 trans w/ 3500 Stall Dirty Dog converter, Mark VIII drive shaft & pumpkin with 3.73 and sct tuned. Mid mount Magnaflow di/do, kyb's and springtech springs. Tuned by Precision Autosports.
Best time 13.91 @ 97
http://i3.photobucket.com/albums/y57...arterView2.jpg
henry74 is offline
post #2 of 8 (permalink) Old 04-20-2010, 04:33 PM
dDUBb's Avatar
Was the trans working in the 96 Tbird ??
dDUBb is offline
post #3 of 8 (permalink) Old 04-20-2010, 08:49 PM
95xbird's Avatar
MLPS switch. Make sure its properly lined up. Start there
Its slow, Really.
LS1 KILLER
1995 svo Tbird. R.I.P.
95xbird is offline
post #4 of 8 (permalink) Old 04-20-2010, 09:36 PM Thread Starter
I'm a bone head, I figured it out. I somehow managed to forget to seat the mlps back into the slot on the inside of the trans. It works now, pretty sad it took me a couple of days to figure it out.
henry74 is offline
post #5 of 8 (permalink) Old 04-20-2010, 10:37 PM
94TchikinV8's Avatar
Send a message via AIM to 94TchikinV8 Send a message via Yahoo to 94TchikinV8
Glad you got it figured out Rick. I'm going to be back in town Thursday afternoon probably. Kil-Kare?
-Rob
1994 Thunderbird LX V8
Still in pieces in the garage awaiting body work, paint, and a drivetrain...
Currently driving a 98 Mustang GT convertible:
02 Explorer engine, Comp 262ah cams, Steeda underdrives, aftermarket H-pipe with high flow cats, SLP LM1 exhaust, MGW shifter, RAM clutch
[email protected], 2.17 60ft(stock 2.73s, worn-out trac-lok)
94TchikinV8 is offline
post #6 of 8 (permalink) Old 04-20-2010, 11:11 PM Thread Starter
I am not sure yet, I still have to finish up the exhaust and a small coolant leak. I drove down to the end of the block and it seems to be okay but in park and neutral it is idling a little high 1200 rpms. Might be from all the changes and no cats yet. I am going to try to get it finished tomorrow.
henry74 is offline
post #7 of 8 (permalink) Old 04-21-2010, 07:33 PM
Did you ever get it retuned after the trans and converter?
-Rob
post #8 of 8 (permalink) Old 04-21-2010, 11:25 PM Thread Starter
-Rob
I had it tuned after we put in the converter and trans. I think it just needs to be tuned again after all of the changes this go around. I thought I would have fixed the oil leak with a new pan gasket but it turns out to be even worse...when rains it pours!
henry74 is offline
