reverse acting strange - TCCoA Forums
post #1 of 3 (permalink) Old 04-25-2010, 10:28 AM Thread Starter
1995 cougar xr7's Avatar
i have reverse but its very slow, i can give it more gas but it still backs up with the same speed. any ideas
1995 cougar xr7 is offline
post #2 of 3 (permalink) Old 04-27-2010, 07:46 AM
sounds like REV band or rev clutches weak, or piston seals weak. Not a common thing, but more frequent in trucks. A new rev band piston might solve it, but if the seal is hard on that, then the internals are close behind.
www.Silverfoxtrans.com
www.clickclickracing.com
SilverFox is offline
post #3 of 3 (permalink) Old 05-23-2010, 12:56 PM Thread Starter
so do you think changing the reverse servo piston and rod and spring will fix the problem
