trans counter weights - TCCoA Forums
post #1 of 6 (permalink) Old 04-27-2010, 11:07 AM Thread Starter
danalba's Avatar
just had my trans rebuilt and he said the old housing had counter weights is what he called them on the tail. he said the one he took off my car didnt have them so he wasnt able to put them back on but he said they are supposed to be there and that i should look into getting it fixed. i was wondering if someone could help me with this. on where i could get them maybe from a dealer or something or if they HAVE to be on there ????
MAC CAI/02 STANG MAF/SCT CHIP TUNED BY LONNIE
EIBACH 1.5 LOWERING SPRINGS- BILSTEIN GAS SHOCKS
90 SUPERCOUPE SIDE SKIRTS/REAR
18x9-FRONT: 245 REAR: 275
PI intake/PI cams
355 trac lok
new tune for swapped parts (93 oct)
no longer the owner.... but its still my child its just released into the world....
danalba is offline
post #2 of 6 (permalink) Old 04-27-2010, 12:26 PM
dDUBb's Avatar
They are only on the 97's ... they were put on to help with Vibrations at Idle. It wont matter it you dont have the counterweight on the back of the transmission, most of us here do not have it as well.
dDUBb is offline
post #3 of 6 (permalink) Old 04-27-2010, 12:28 PM Thread Starter
danalba's Avatar
ok. thanks thats all i needed to know. i just didnt want it to cause issues without it
PI intake/PI cams
355 trac lok
danalba is offline
post #4 of 6 (permalink) Old 04-27-2010, 01:12 PM
If you run it without the counterweight be sure to loctite the tailshaft housing bolts. I've seen them loosen time and time again causing leaks, then torque to spec and enjoy.
post #5 of 6 (permalink) Old 04-27-2010, 01:24 PM
Nitemare's Avatar
If this is that random solid black tube on the tailshaft of the transmission, then my 96 has it.
Needs more stall.
Nitemare is offline
post #6 of 6 (permalink) Old 04-27-2010, 02:14 PM
dDUBb's Avatar
Yeah probably .. it was a late model feature. When was your build date ?
Ive never loctited the bolts a tailshaft .. that has nothing to do with the housing coming off.
dDUBb is offline
