trans cleaning tips? - TCCoA Forums
post #1 of 8 (permalink) Old 05-10-2010, 01:36 AM Thread Starter
Well now that I have it all torn down anyone have tips on cleaning both
inside and outside the case with out damaging anything? Maybe even just a
link to a site with these tips?
**Note** Obviously as many are this way the outside of the case is pretty bad
grime trans fluid dirt caked on.
Dominick is offline
post #2 of 8 (permalink) Old 05-10-2010, 02:14 AM
Mineral spirits is what I use.
post #3 of 8 (permalink) Old 05-10-2010, 07:06 PM Thread Starter
that strong enough for the caked on stuff? Also is brake cleaner to harsh?
Dominick is offline
post #4 of 8 (permalink) Old 05-10-2010, 08:19 PM
RESET's Avatar
Should have taken the case to the car wash before tearing it apart. That is the best way of getting the nasty stuff off.
RESET is offline
post #5 of 8 (permalink) Old 05-10-2010, 09:10 PM Thread Starter
Yeah when I get it all apart I thought the same thing and was kinda kicking myself.
Tho I do have a power washer.
Dominick is offline
post #6 of 8 (permalink) Old 05-10-2010, 09:24 PM
RESET's Avatar
Maybe you can bolt the covers back on and still power wash it? I would still be afraid of getting grit into the case and not get it out later.
RESET is offline
post #7 of 8 (permalink) Old 05-19-2010, 01:00 PM
I have a steam cleaning pressure washer and do my own cases with it...I get wet...and hot...and grimy...but works as good if not better than some other washers I can't afford.
I had a guy bring me a case that was SODA blasted...it was STRIPPED and paint took to it like a magnet...but I had to recondition the servo/accum bores.
www.Silverfoxtrans.com
www.clickclickracing.com
SilverFox is offline
post #8 of 8 (permalink) Old 05-20-2010, 04:21 AM
Pressure washer and any chemical degreaser/cleaner that is safe for aluminum. I've used Terra Kleen as it's produced locally to me and is what my local trans shop uses, safe for hands, carpet, engines, bio safe, and cleans like no other.
