shift points - TCCoA Forums
post #1 of 3 (permalink) Old 05-20-2010, 10:16 PM Thread Starter
richs1000's Avatar
Send a message via AIM to richs1000
shift points
Why is it when i floor it, it shifts at like 4300 rpm going from 1st to 2nd instead of redline? Then 2nd to 3rd is a little higher.
richs1000 is offline
post #2 of 3 (permalink) Old 05-21-2010, 08:17 AM
rmfk13's Avatar
Thats how the car is built, Heres what you can do to have it shift at higher RPMS, drop it all the way down to first or the #1, and make it redline. make sure to shift up to #2 and let off the gas around 5200 rpms if you do do this. OR you can put the OD off, if your button still works, if I remeber correctly it should climb to the higer RPMS you need. Why do you need the high RPMS anyway??
rmfk13 is offline
post #3 of 3 (permalink) Old 05-21-2010, 12:05 PM Thread Starter
richs1000's Avatar
I dont need higher rpms. I was just wondering.
