Loud clank when shifting into gear - TCCoA Forums
post #1 of 12 (permalink) Old 05-22-2010, 08:09 PM Thread Starter
danalba's Avatar
pretty much what it says. not sure if it will cause any harm or not. doesnt sound very healthy, i just had it rebuilt and when i put it into gear whether it be drive or reverse more often when in reverse it makes a loud clank noise like the gears are coming together really hard or something. it doesnt do it everytime but 90% of the time it does.... any ideas help?
MAC CAI/02 STANG MAF/SCT CHIP TUNED BY LONNIE
EIBACH 1.5 LOWERING SPRINGS- BILSTEIN GAS SHOCKS
90 SUPERCOUPE SIDE SKIRTS/REAR
18x9-FRONT: 245 REAR: 275
PI intake/PI cams
355 trac lok
new tune for swapped parts (93 oct)
no longer the owner.... but its still my child its just released into the world....
danalba is offline
post #2 of 12 (permalink) Old 05-22-2010, 08:39 PM
cobra R Thunderbird's Avatar
Mine does the same thing bro.. My 3rd bird and my past 2 did the same thing.. I guess its normal? Idk, ill find out after I put my built differentail in..
2001 GT BULLITT #00762 stock
post #3 of 12 (permalink) Old 05-22-2010, 09:40 PM
The_coop_08's Avatar
Send a message via AIM to The_coop_08
Sounds like u joints
Silver 96 T-bird
Major Mods: Stage II PI head swap w/Stage II cams, Kooks headers, 2.5" exhaust with borla xr1, 9.5" Converter 3800 stall, Aluminum rear 3:73 gears, lots of suspension and bolt ons. 13" Cobra brakes, ss lines, lowered 1.6" on staggered saleens
Tim Barth tuned at MPH 274rwhp/298rwtq on 93
Compiling parts for Vortech build
95 SC 5 speed: bone stock for now
The_coop_08 is offline
post #4 of 12 (permalink) Old 05-22-2010, 11:52 PM Thread Starter
danalba's Avatar
U-joints were replaced with the new trans and I put in a brand new drive. when I have the break applied and engage it is when it happens. like I said more times than not when putting it in reverse. almost eveytime. occasionally when putting it into drive.
PI intake/PI cams
355 trac lok
danalba is offline
post #5 of 12 (permalink) Old 05-23-2010, 12:09 AM
loose driveshaft flange bolts at the diff, possibly. They're a drag to tighten with a 12 point wrench.
post #6 of 12 (permalink) Old 05-23-2010, 12:24 AM
Check the mounts!
post #7 of 12 (permalink) Old 05-23-2010, 08:57 AM Thread Starter
danalba's Avatar
how can I tell if the mounts are bad?
and I'll see if I can tighten the bolts your talking about. are they torqued?
PI intake/PI cams
355 trac lok
danalba is offline
post #8 of 12 (permalink) Old 05-23-2010, 01:14 PM
sousa632's Avatar
Originally Posted by dirtyd0g View Post
Check the mounts!
I'll second this one. I know I need new mounts and mine clicks every once in a while going to reverse.
John
1996 TBird LX 4.6
2001 Sable Wagon 3.0 Duratec
sousa632 is offline
post #9 of 12 (permalink) Old 05-23-2010, 01:16 PM
thunderclaw's Avatar
does it do it when ur parked only? how about while ur moving? when the tranny downshifts? i have the same problem while im driving. i've been under the car numerous times but no loose parts(driveshafts, tranny mounts, ect...)im guessing loose pinion nut (if u have mess with it like i did) or worn out limited slip differential internals(i have a lot of play in it (while on jack, tranny in neutral, rotate driveshaft by hand back and forth, my driveshaft rotates alot b4 my wheels do)
thunderclaw is offline
post #10 of 12 (permalink) Old 05-23-2010, 05:34 PM Thread Starter
danalba's Avatar
ya I'll keep looking into it. I can't tell when moving. it kind of makes a noise when downshifting. not like when I put it into gear though. idk
PI intake/PI cams
355 trac lok
danalba is offline
post #11 of 12 (permalink) Old 06-06-2010, 05:29 AM
Wonder if this clank could be caused by the tailshaft bushing? Try to check your endplay, i have the same symptoms and i am leaning towards that. I have been reading around and some people have had there trans rebuilt by people that have forgotten to install new bushings in the extension housing. They often go bad quickly with the stock driveshaft as well. Just a thought...
Silver 96 T-bird
post #12 of 12 (permalink) Old 06-06-2010, 06:57 AM
nall_one's Avatar
yeah, that big rubber tailshaft bushing is also very easy to rip apart trying to get the nut off, what happend to my 95. whenever i get the trans back together with the Jmod im planning on grabbing a new one since the stud spins in the rubber now.
like others are saying check the play, wedge a prybar up in their and try to move the trans back and forth. just dont bust off the sensors :P
nall_one is offline
