1997 4r70w - TCCoA Forums
post #1 of 18 (permalink) Old 01-01-2002, 04:16 PM Thread Starter
KStromberg's Avatar
Originally Posted by LoadedButane View Post
I have a bone stock original 95 with no tranny cooler on it that is over 200k and shifts perfect.
Yes, and your car is stock.
1998 Lincoln Mark VIII LSC
1997 Lincoln Mark VIII LSC Supercharged
1992 F150 XLT
KStromberg is offline
post #2 of 18 (permalink) Old 05-23-2010, 11:53 PM
richs1000's Avatar
Send a message via AIM to richs1000
1997 4r70w
How reliable are the 97 4r70w? any issues with these?
Rich
US Air Force
Oil Leak? No thats the frame lubricator.
richs1000 is offline
post #3 of 18 (permalink) Old 05-24-2010, 01:23 AM
richs1000's Avatar
anyone?
Rich
US Air Force
post #4 of 18 (permalink) Old 05-24-2010, 05:30 AM
97's are the best of the thunderbird/cougar ones because they have about a 50% chance of having the mechnaical diode. Typically they last anywhere from 60,000 to 150,000 miles depending on usage and driving style. That was considerably better than the 94/95 units which were usually replaced under warranty.
post #5 of 18 (permalink) Old 05-25-2010, 06:24 AM
richs1000's Avatar
whats a diode? my car was built 05/97
Rich
US Air Force
post #6 of 18 (permalink) Old 05-25-2010, 01:13 PM
Start here...
http://tccoa.com/articles/tranny/tra...on/index.shtml
Then ask questions.
It's much easier in the long run.
post #7 of 18 (permalink) Old 05-25-2010, 02:11 PM
richs1000's Avatar
hey thanks for that link
Rich
US Air Force
post #8 of 18 (permalink) Old 05-26-2010, 10:59 AM
richs1000's Avatar
well tommorow im taking the t-bird to a shop. They will drop the pan, change filter and some fluid.
Rich
US Air Force
post #9 of 18 (permalink) Old 05-27-2010, 10:15 AM
richs1000's Avatar
OMG. shifting is so much better now. they claimed its never been done before.
Rich
US Air Force
post #10 of 18 (permalink) Old 05-27-2010, 11:36 AM
Uh oh...good luck with it. I predict it doesn't last another 5000 miles.
post #11 of 18 (permalink) Old 05-27-2010, 11:59 AM
richs1000's Avatar
why you say that?
Rich
US Air Force
post #12 of 18 (permalink) Old 05-27-2010, 12:18 PM
Typically proper servicing does nto fix problems it prevents them. When it fixes a problem the fix is usually short lived.
post #13 of 18 (permalink) Old 05-27-2010, 12:47 PM
richs1000's Avatar
hmm. well the old fluid wasnt brown so its not like i went from brown to red.
Rich
US Air Force
post #14 of 18 (permalink) Old 05-27-2010, 03:35 PM
That is good, hope it works out.
post #15 of 18 (permalink) Old 05-29-2010, 05:10 AM
richs1000's Avatar
so the guy from the shop said that he found a rubber o ring laying at the bottom of the pan? he said ford used those in the dipstick area. this true?
Rich
US Air Force
post #16 of 18 (permalink) Old 05-29-2010, 07:05 AM
nall_one's Avatar
yeah, its a white plug, with an o-ring around the edge, they plug the dipstick hole with them while they are putting the car together, when they pop the dipstick in, it pushed the plug down into the pan where it stays till the pans removed.
dosent mean you didnt have a fluid change, but its most likely you didnt. most shops you take your car to for a fluid change disconnect the cooler lines and run new fluid in and out through those till it comes out clean on the return. so they never take the pan off, or remove the filter, its actually not required in some transmissions that have a metal mesh filter. ours are cloth, so its a good idea to change them.
nall_one is offline
post #17 of 18 (permalink) Old 06-10-2010, 01:41 PM
After reading this series of posts I still sometimes wonder at all if I have the longest lasting 4R70W out there.
My car in question, '96 Cougar with the 4.6, just turned 175,000 miles and the original transmission is still running and hitting all shifts. I still think the best decision I made with this car was installing a tranny cooler nearly 10 years ago and doing the Jmod.
I'm thankful this tranny is still going. I can't count the number of stories I've read about how soon these transmissions fail.
Wldcat8 is offline
post #18 of 18 (permalink) Old 06-10-2010, 01:53 PM
Send a message via AIM to LoadedButane Send a message via Yahoo to LoadedButane
Geoff
1995 Mercury Cougar
~Mark VIII Trans with jmod + converter, 255lph fuel pump
~heads, cams, and intake in the distant future or when I break something
LoadedButane is offline
