HELP! I think I am an idiot.... - TCCoA Forums
post #1 of 5 (permalink) Old 06-01-2010, 11:57 AM Thread Starter
and shouldn't have attmepted this transmission swap. i am utterly confused at this point. I have a rebuilt 03 mustang 4r70w (long story), that will "bolt right up to a mustang" according to the builder. What all needs to be done to put it in my 95 t-bird. I know about the MLPS and alread have that. I thought I had to replace the TCC solenoid, but the person that built the transmission said it is imossible to put the old TCC solenoid in the new transmission. Hence, my confusion. Does the internal wiring harness need to be replaced with an older one? I have searched the site(multiple times) and read the tech article and the only suggestions regarding 2003 transmissions I could find was "don't get one", but I am beyond that unfortunately.
Any help would be greatly appreciated!
Seth
BTW- - I do have the correct output shaft installed already.
[email protected]=iii=<| is offline
post #2 of 5 (permalink) Old 06-01-2010, 12:51 PM
AFAIK, yes, you have to change the MLPS, the TCC solenoid, and re-pin the harness connector. You may also have to change form the circuit board connections to the older-style wire connections. Somebody will pipe in here and let you know, I'm sure.
post #3 of 5 (permalink) Old 06-01-2010, 01:14 PM Thread Starter
Herein lies my problem I believe. I hope someone will chime in. I am aware of the MLPS and repinning harness and already have those accomplished.
Thanks.
Seth
post #4 of 5 (permalink) Old 06-01-2010, 01:29 PM
You're not an idiot. Your just an uneducated, incompetent, country bumpkin' Mississippi transplant. Idiots work for BP
Give RobertP a call in the morning (around 9 am EST) he'll be able to help ya out. His number is on his website - link in my sig.
Good luck getting it worked out. Sorry you're having such trouble with it. I thought you'd be done by now.
post #5 of 5 (permalink) Old 06-01-2010, 02:30 PM Thread Starter
thanks trunk. I've moved up in the world. i live above arkansas now. :P I think i got my questions answered. I talked to Alan. I think there has been something lost in translation when speaking with the transmission person i have been dealing with. He probably is not used to having to cut stuff to make it fit. i hope to be done with it soon enough. i hope to get the torque converter from alan via ups tomorrow. It just depends on what time it gets here.
thanks
seth
