97 trans issues im not really sure on - TCCoA Forums
post #1 of 3 (permalink) Old 06-02-2010, 10:35 AM Thread Starter
danalba's Avatar
Unhappy 97 trans issues im not really sure on
so i read all through the tech articles. i have a 97 4r70w that i just had replaced so im pretty upset its acting up.
so first thing... the trans seems to be shifting fine. it shifts firm and when it should.
however when i put it into gear whether reverse or drive i get a buzzing noise which the tech articles said should occur in 95 and earlier valve bodies, mine is a 97? possible the trans was replaced with an older 4r70w? also when in reverse or drive i occasionally get some weird shudder or vibration when the break is applied but not once i start to get going more than just a roll.
also occasionally when putting the trans into gear and when it downshifts (not sure when shifting higher gears) i get a clanking sound like the gears are slamming into gear. its really not too loud but it def does not sound normal, again its not every time.
so with all that im not sure where i should even start. shifts fine fluid is fine so im not sure what to do. the trans being warm or not really does not seem to make a diff.
MAC CAI/02 STANG MAF/SCT CHIP TUNED BY LONNIE
EIBACH 1.5 LOWERING SPRINGS- BILSTEIN GAS SHOCKS
90 SUPERCOUPE SIDE SKIRTS/REAR
18x9-FRONT: 245 REAR: 275
PI intake/PI cams
355 trac lok
new tune for swapped parts (93 oct)
no longer the owner.... but its still my child its just released into the world....
danalba is offline
post #2 of 3 (permalink) Old 06-02-2010, 11:38 AM
It is nice
not really good with trans's but my torque convertor did that when it was dying on my old car even though it had no shift kit
91CougarLS is offline
post #3 of 3 (permalink) Old 06-02-2010, 03:32 PM Thread Starter
danalba's Avatar
well I highly doubt it's the torque converter. I mean I JUST had a rebuilt trans put in it probably a month ago
PI intake/PI cams
355 trac lok
danalba is offline
