Reman. installed - TCCoA Forums
post #1 of 7 (permalink) Old 06-30-2010, 06:53 PM Thread Starter
Reman. installed
Just had a remanufactured tranny installed in the car about a week ago.
My installer said it was out of a 96/97 f150. He had to use my old linkage and pan.
It seems to work as it should under both normal and spirted driving.
I an having 2 issues tho. The first is my back up lights no longer function.
The second is my speedo is showing 13 MPH faster at hiway speeds.
What would cause these two issues and are they easy to repair..
Thanks Brian
skiezo is offline
post #2 of 7 (permalink) Old 06-30-2010, 08:25 PM
bowez's Avatar
Speed is either different count tooth VSS gear or Output shaft gear.
93 SC Tbird
96 1/2 XR7 Sold and Salvaged
93 5.0 Tbird
bowez is offline
post #3 of 7 (permalink) Old 06-30-2010, 09:17 PM
Back up lights is a faulty or misaligned MLPS, The speedometer is because the transmissionhas an 8 tooth output shaft and your stock one had a 7 tooth. With 3.08 gears you need a 20 tooth speedometer gear, for 3.27's you need a 21. beyond that you'll need a speed calibration unit such as the dakota digital or the dallas mustangs speedcal.
post #4 of 7 (permalink) Old 07-03-2010, 07:47 AM
BUCK's Avatar
Thumbs down
Originally Posted by skiezo View Post
What would cause these two issues Thanks Brian
Lack of research prior to install.
BUCK is offline
post #5 of 7 (permalink) Old 07-14-2010, 06:30 PM Thread Starter
The remanufacture was from Jasper. They assured me it was the right tranny.
I did my research and got this through a friend who is a jasper dealer.
So they screwed up, not my lack of research.
Brian
skiezo is offline
post #6 of 7 (permalink) Old 07-14-2010, 06:45 PM
Fyi
Not to start an argument, but I just pulled the speedo gear from my stock 1995 'Bird with 3.08 gears and it was a Green 17 tooth gear. I changed my rear gear to a 3.27 gear set and went to a Gray 18 tooth gear to correct my speedometer (it was about 6% off after the swap).
Are you saying he has a different output shaft, that's the reason for the different tooth gears?
~Rick
TCCoA Sig
post #7 of 7 (permalink) Old 07-14-2010, 07:26 PM
Tire size will make differences, I was basing on stock tires. The rule of them is for every tooth you go up on the output shaft you need 2 on the sensor. so 19 or 20 you are probably in a decent limit.
