O/D Switch Replacement - TCCoA Forums
post #1 of 6 (permalink) Old 07-09-2010, 02:33 PM Thread Starter
Arrow O/D Switch Replacement
I own a 1995 Cougar 4.6, recently the Overdrive switch/button burned out and I have no clue as to how I get the shifter knob off to replace it..can anyone hlp me out??
1995XR7 is offline
post #2 of 6 (permalink) Old 07-09-2010, 02:35 PM
The button just pops out. You might want to use a pick or small flathead screwdriver to pry it out, but there are no clips or retainers holding it in. You don't need to remove the shifter.
post #3 of 6 (permalink) Old 07-09-2010, 02:49 PM Thread Starter
ok cool thank you!...ok, i removed the button and it all looks fine...
1995XR7 is offline
post #4 of 6 (permalink) Old 07-09-2010, 02:54 PM
To test the switch, use a multimeter. Press the probes against each of the two contacts and then press the button. As long as the button is pressed, there should be continuity between the two contacts. If the switch is fine, then check the fuses.
post #5 of 6 (permalink) Old 07-09-2010, 06:13 PM
danalba's Avatar
had the same problem, honestly i feel it would be easier to just remove the clip in the front of the shifter and take the whole shifter right off. its not hard. and i think you need to do this anyways if it needs to be replaced. correct me if im wrong master486
MAC CAI/02 STANG MAF/SCT CHIP TUNED BY LONNIE
EIBACH 1.5 LOWERING SPRINGS- BILSTEIN GAS SHOCKS
90 SUPERCOUPE SIDE SKIRTS/REAR
18x9-FRONT: 245 REAR: 275
PI intake/PI cams
355 trac lok
new tune for swapped parts (93 oct)
no longer the owner.... but its still my child its just released into the world....
danalba is offline
post #6 of 6 (permalink) Old 07-11-2010, 10:48 AM
BUCK's Avatar
Thumbs up
You can definitely replace button without removing Shifter handle - & not a bad idea to pop the button out prior to sliding off Shifter handle should you choose too - There are instances of the fine wires from Strip chafing & shorting in Shifter - The Copper strips the Button mates to are darn flimsy & the assembly VERY peculiar about all being in place for it to work properly or you'll have it apart several times - Have a fuse handy too...
BUCK is offline
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
lp2v
