coolant inside - TCCoA Forums
post #1 of 3 (permalink) Old 07-21-2010, 01:58 PM Thread Starter
coolant inside
Uh-oh! I had a leaking intake and upgraded to the pi intake thinking I was done.
Low coolant came on again. !;&@ thermostate gasket. Replaced w/ O-ring. Not that either.
D...n tank was letting coolant in the tranny. So I let it sit for a couple of weeks and drain everything.
Looked like it had that krispy kreme glaze on everything. Filled'er up w/ mercon5 and
a can of seafoam transtune
and heated it up. Started driving it slow and short trips w/ no trouble. Now it shudders bad
going into 2nd. The last time I drove it lost almost all drive as I had to coast the last 200 ft.
Could this be a stuck accumulator? What should be my next step?
L. Thomas
97 Tbird Sport
99 J-Mod Tranny
PBR calipers
270K miles and still flying, just not daily!
Generalee is offline
post #2 of 3 (permalink) Old 07-21-2010, 07:26 PM
Chapter Director Coordinator
jamesD's Avatar
did you flush the cooler lines and replace the radiator?
I bust ARP bolts by hand...
If Guns kill people, then...
...pencils miss spel werds
~Gun Owners of America
jamesD is offline
post #3 of 3 (permalink) Old 07-22-2010, 12:23 PM Thread Starter
Question
Yes I flushed the lines and the xtra cooler before I bypassed the radiator and added the second cooler in series. I should probably check to see what the fluid temp is to be sure it is cooling adequately. I just plugged the inlets on the rad to keep from replacing it.
L. Thomas
97 Tbird Sport
99 J-Mod Tranny
PBR calipers
