Need answer FAST - TCCoA Forums
post #1 of 5 (permalink) Old 07-23-2010, 05:58 PM Thread Starter
'94bird's Avatar
Need answer FAST
Does it matter what direction you turn the crankshaft when trying to align the torque converter drain bolt with the hole?
1994 Ford Thunderbird 4.6 SOHC........Air silencer delete, muffler delete (LOL), and smoked tails......SOLD!
Current: 1987 Lincoln Mark VII LSC 5.0 HO 3.27 gears
'94bird is offline
post #2 of 5 (permalink) Old 07-23-2010, 06:31 PM
Ummmm, no? Why would it. Except if you turn it lefty you might just loosen the bolt, not turn the engine...
That's why I always turn clockwise so as not to loosen the bolt.....
~Rick
TCCoA Sig
post #3 of 5 (permalink) Old 07-23-2010, 06:37 PM Thread Starter
'94bird's Avatar
Thanks, maybe it was a dumb question, I just did not know if there was a difference. I really appreciate the quick response.
One more, How do you fill it back up? Through the filler neck in the engine compartment?
'94bird is offline
post #4 of 5 (permalink) Old 07-23-2010, 06:43 PM
Moderator & Teksid Whore
guitar maestro's Avatar
yup...put in about 6 qts....turn the car on....go from P to N to R to D to 2 to 1, leaving it in those positions for about 10 seconds each, then go back from 1 to P, again leaving each position in for about 10 seconds......then shut off the car and fill up the rest til the trans fluid dipstick is full, which should be another 6 qts or so.......the trans holds a couple more quarts, but the level won't drop until you do some easy driving...so just take it around for a spin to engage all gears then check it again when hot and you should be able to add another quart or two
guitar maestro is offline
post #5 of 5 (permalink) Old 07-23-2010, 06:47 PM Thread Starter
'94bird's Avatar
Awesome, you guys are the best
'94bird is offline
