4r70w's from V-6 vs V8 - TCCoA Forums
post #1 of 7 (permalink) Old 08-04-2010, 11:27 AM Thread Starter
Scott Suzanne's Avatar
Send a message via Yahoo to Scott Suzanne
My friend needs a trans in his 96 4.6 T-bird and can get a 4r70w out of a 96 3.8 car. Are there differences between the trans put in V-6's vs. V-8's? Will a v-6 trans work in a v-8 car? He is trying to keep this on the really really really cheap (v-6 trans is free, came out of a running car, motor used in a different swap.)
Thanks.
97 Mercury Cougar "Project Eliminator" 385 RWHP 400 RWTQ
2000 GT PI 4.6 Liter with Coil-on Plug Mod, Tork Tech Inc. M112 Supercharger
BC-Automotive 4R70W and Torque Converter by Darrin, 3.73:1 rear gear, Aluminum Driveshaft,
Kooks 3/4 Length Headers, Custom Mandrel-Bent Exhaust, Vogtland 3/4" Lowering Springs,
18x9.5 GT500 Wheels, 255-45-18 front 285-40-18 rear by Custom Wheel Shop.
Under Construction
2010 Mustang GT
Daily Driver / Stock
Scott Suzanne is offline
post #2 of 7 (permalink) Old 08-04-2010, 11:32 AM
Won't work. The 3.8 has the SBF bell housing, and the 4.6 is a modular motor, so the trans physically won't even bolt up to the engine.
post #3 of 7 (permalink) Old 08-04-2010, 03:28 PM
thunderclaw's Avatar
if trying to keep as cheap as he said. could we at least swap the internals?and make 1 transmission out of 2 tiil we save up for rebuild (assuming that we're doing all the work, of course)
thunderclaw is offline
post #4 of 7 (permalink) Old 08-04-2010, 04:33 PM
You could do that, but then you would have done just as much work as rebuilding it, only to have a weaker transmission than stock. Your best bet is to go to a junkyard and pull a 4R70W out of anything with a 4.6. Preferably find the most f-d up car in the yard to grab the trans out of, because that way you know it drove to the scene of the accident, and therefore the trans probably works.
post #5 of 7 (permalink) Old 08-04-2010, 09:05 PM
Someone that scouts cars like I do; scary!
I've done one for each car so far; you can find some nice low mileage trannys in Gran Marquis, and crown vics. Anything earlier than 03 will work; 03+ may not have the VSS drive teeth on the output shaft. It also can't be one from a police car; they're longer.
I bought ones that had 12k, 22k, and 40k, all ~$450 each. All were rear end collisions; very messy.
There was another one at about 12k miles, but the bellhousing had a crack in it; when I looked closer, I saw the driveshaft had been driven into the tranny. I did not know that would fit there, lol. (the side away from me was broken off...)
post #6 of 7 (permalink) Old 08-08-2010, 12:19 AM Thread Starter
Thanks for the info Guys, i will pass it along. Looks like a junkyard trip in his future.
Under Construction
2010 Mustang GT
post #7 of 7 (permalink) Old 08-09-2010, 12:01 PM
Chapter Director Coordinator
jamesD's Avatar
i got a fully built one for sale for $1000.. not that far from Georgia.. just an idea...
I bust ARP bolts by hand...
If Guns kill people, then...
...pencils miss spel werds
~Gun Owners of America
jamesD is offline
