Is my 4r70w trashed after the accident? - TCCoA Forums
post #1 of 7 (permalink) Old 08-05-2010, 09:42 PM Thread Starter
Rob
Rob's Avatar
Send a message via AIM to Rob
I got under the bird yesterday and it appears that the front of the car (subframe and subsequently, the engine) have been pushed back like 2 inches. The DS yoke is jammed all the way into the tailhousing and is leaking fluid through the yoke it appears. My driveshaft also broke in two right in front of the gas tank. Do you think my transmission is ok? The one in the 96 is rebuilt already, but the possibly broken one I have is like an 01 or 02 crown vic trans. I was hoping this would all be good.
Has anyone had bad experiences using a transmission that had the yoke shoved in it? I think I can just replace the seal and be on my merry way after changing the filter and fluid. Thanks in advance.
-Rob
Rob is offline
post #2 of 7 (permalink) Old 08-08-2010, 12:43 PM Thread Starter
Rob
Rob's Avatar
Well damn. I guess I will inspect it closer when it hits the ground today.
-Rob
Rob is offline
post #3 of 7 (permalink) Old 08-08-2010, 02:39 PM
cobra R Thunderbird's Avatar
Only suggestion I have is disconnect the DS from the yoke, put the tranny in neutral and spin the yoke and c how it feels.. Feel for grinding and listen to how it sounds.. If it feels rite and makes that normal 'hum' sound then it should be fine
2001 GT BULLITT #00762 stock
post #4 of 7 (permalink) Old 08-08-2010, 07:18 PM
Darrin's Avatar
I definitely wouldn't put it in a car without taking it completely apart and inspecting everything first.
Darrin
Darrin is offline
post #5 of 7 (permalink) Old 08-09-2010, 08:58 PM Thread Starter
Rob
Rob's Avatar
Well I pulled the engine,trans,subframe, and exhaust last night in one piece, the driveshaft slid right out. I think I will just replace the seals and see if it works. If not, the trans in the 96 just got rebuilt. I believe I can swap the newer 01+ Crown Vic valve body into the 96 trans. Is this correct? Thanks
-Rob
Rob is offline
post #6 of 7 (permalink) Old 08-09-2010, 10:06 PM
Raptor22's Avatar
How hard did you hit? I hit a center median doing 50 MPH and the left front wheel took the brunt of the impact completely demolishing my suspension the process, however it did not bend my unibody or move the engine or transmission...
Made it easier for me to get another subframe and rebuild it...
[-----[ Conner ]-----] ASE P2 Automobile Parts Specialist - P4 General Motors Parts Consultant
The Blunderbird - 1989 Ford Thunderbird
3.8L V6 / M5R2 / 145,005 miles
Thunderbird SC Suspension Swap - Eibach Pro-Kit
JBL Premium Audio Swap - JL CP108 Subwoofer
Resonator Delete - Magnaflow DI/SO Muffler - Custom 2.5in Exhaust
Raptor22 is offline
post #7 of 7 (permalink) Old 08-09-2010, 10:20 PM Thread Starter
Rob
Rob's Avatar
It was a hit to the front of my body and subframe from the side. We had to use a sawzall and a hydraulic ram to get the body to clear the engine, lol. Looks like I will be using 96 valve covers on this engine. After seeing the trans in person, I think it will be fine with a new seal, but who knows what may have happened inside. Time will tell BTW, that was sweet about getting a new subframe. I wish that was all that happened to my baby
-Rob
Rob is offline
