Automatic tbird stalling in drive - TCCoA Forums
post #1 of 8 (permalink) Old 08-09-2010, 08:44 PM Thread Starter
The car starts up fine, idles fine, and then I put it in drive and sometimes it will jump alittle, but when i put gas to it, it just dies. It started yesterday while I was driving and i just stalled out in the middle of the intersection. Any ideas?????
dorkfish is offline
post #2 of 8 (permalink) Old 08-09-2010, 11:51 PM
IAC?
RalphP is offline
post #3 of 8 (permalink) Old 08-10-2010, 01:01 AM
Check for vacuum leaks first.
post #4 of 8 (permalink) Old 08-10-2010, 07:59 AM
95xbird's Avatar
My car does this too. Its not always a vacuum leak but you should definitely check for leaks first. Mine dies because the plugs are fouled out from the meth kit.(Sprays early) Try vac leaks and a good ol' MAF cleaning.
Its slow, Really.
LS1 KILLER
1995 svo Tbird. R.I.P.
95xbird is offline
post #5 of 8 (permalink) Old 08-11-2010, 09:51 AM
SuperNewbie
supergordo's Avatar
The car does have an AED on it. But checking for vacuum leaks would make sense. And of course seeing as how the IAC is in a terrible place to get to it could be that too like RalphP mentioned. So basically I have nothing new to offer to this conversation. haha!
Wish that I could come help you out. Get me a mac flight to the east coast???
1995 Cougar XR7 4.6
1997 Thunderbird LX 4.6
1977 Country Squire 460
1985 Capri RS 5.0, 5spd
1997 Thunderbird 4.6
1984 Capri RS 5.0,5spd
supergordo is offline
post #6 of 8 (permalink) Old 09-28-2010, 09:53 AM Thread Starter
I have finally got time to check the problem out. No vacuum leaks that I can find. I am able to drive it with no problems when it is cold, but once it is all warmed up it after I turn it off it will not start again until it is cooled off again. I don't have the money to take it to a shop.... Any other things that it could be?
dorkfish is offline
post #7 of 8 (permalink) Old 09-28-2010, 10:10 AM
BUCK's Avatar
Question
I Second checking the IAC first - But as we're in Tranny Forum seems like D/Dog sometimes analyzes this as a frozen Direct Drum to Sun Shaft Bushing or something like that really BAD & pretty common on our Gen Tranny - The lube holes are VERY teeny & if the Bronze Bushing scores &/or spins a tad the lube holes get totally Blocked & it;s Game Over - Mine was on the way out when I blew Roller OWC - Tranny O/Haul & some hard parts the fix.
BUCK is offline
post #8 of 8 (permalink) Old 09-28-2010, 03:05 PM
Faster than Porkchop
cjchevez's Avatar
On my old Camaro it was the fuel pump relay that was corroded and when it got hot it lost its contact so the car would stall and not start till it cooled down.
12 dollar part and the shop wanted 600.00.
well good luck!
1997 Ford Thunderbird 4.6 Sport .
60'...... 2.06
1/8th .. 9.194
mph .... 77.13
mods*
PI heads *PI intake*Mark VIII torque converter*Cobra T-loc w\4.10's * Jmod*tranny fluid cooler*P&P stock T/B & plenum*UD pulleys* Dynotech 4in ds*80mm Lightning maf*Xcal2*02 GT intake tube.
cjchevez is offline
