cooler ? - TCCoA Forums
post #1 of 4 (permalink) Old 08-17-2010, 11:37 AM Thread Starter
Question cooler ?
Radiator tank filled the tranny w/ coolant. I have installed two (2)
B & M supercoolers in series and
bypass the tank outright. Will this
cool the fluid down enough or
should I add a fan? It has been
very hot here (95+) and if I toast
this tranny (if it isn't already
trashed) the whole thing might
have to go to the bone yard.
L. Thomas
97 Tbird Sport
99 J-Mod Tranny
PBR calipers
270K miles and still flying, just not daily!
Generalee is offline
post #2 of 4 (permalink) Old 08-17-2010, 04:30 PM
Whatever you do with the coolers, flush the trans, converter and coolers a few times. The clutches & electronics do not mix well with antifreeze.
Mitch
MitchB is offline
post #3 of 4 (permalink) Old 08-17-2010, 05:00 PM Thread Starter
I added a can of seafoam transtune and warmed it up
before draining and re-filling. It started shuddering when
shiftting into 2nd and then acted like it was stuck between gears
as it did not feel like it was engaged. I haven't driven it since
and I was hoping the heat might be the culprit instead of
something more.
L. Thomas
97 Tbird Sport
99 J-Mod Tranny
PBR calipers
post #4 of 4 (permalink) Old 08-17-2010, 06:16 PM
southbound's Avatar
I just went threw this myself...
As of right now I have a super cooler from Rob installed.I bypassed the radiator completely and all seems fine. O and it is HOT here too... I will installing a new radiator also at some point....
southbound is offline
