4R70W fault code 639 - TCCoA Forums
post #1 of 4 (permalink) Old 08-29-2010, 11:39 PM Thread Starter
Having a hard time trouble shooting this code.
The EEC seems to be fine, The 2 wires from EEC to OSS have good continuity,
OSS resistance is 515Ω trans book calls for 450 - 750Ω, neither pin on
sensor is shorted to ground, Also the trans seems to be stuck in limp mode
because of it I only have second gear lol.
EEC is a known to be good W4H0 out of a 95 mustang, This was all
working before the harness needed a rewire.
Hope someone can shed some light on this problem, And if anymore info
is needed ill be happy to share.
Dominick is offline
post #2 of 4 (permalink) Old 08-30-2010, 02:18 PM
Originally Posted by Dominick View Post
EEC is a known to be good W4H0 out of a 95 mustang, This was all working before the harness needed a rewire.
It might help if you explain what exactly you rewired and why.
post #3 of 4 (permalink) Old 08-30-2010, 05:04 PM Thread Starter
Sorry about that. The old harness was trashed. So the kit I have is from
http://www.thedetailzone.com It's wired up per the instructions.
Also can the sensor read good ohm's but still produce bad signal?
Dominick is offline
post #4 of 4 (permalink) Old 08-30-2010, 05:21 PM
Sure, a sensor can do that. All the ohm reading gives you is the resistance of the circuit. It doesn't mean the signal will be the correct waveform the computer needs.
