need install advice 03 mach 1 trans/converter into 94 bird - TCCoA Forums
post #1 of 19 (permalink) Old 09-14-2010, 02:29 PM Thread Starter
After reading every thread i could find on this site about 03 tranny installs into a 94 thunderbird, im still not fully confident i have a 100% complete list of things that need to be done for the swap. I bought a 2003 mach 1 trans and stall with only 2k miles on it for $800, hope i got a decent deal. I had them verify twice that it does have the correct output shaft for the speedo gear before i purchased.
Here is a list of things that ive read that will be required for the swap.
swap over the manual lever assy<-----does this assembly include linkage rod?
new 94 TCC solenoid & shift solenoids
new 94 MLPS switch/adjust?
swap internal harness or repin connector
swap my VSS sensor over
swap my oss sensor over
speedcal to correct the speedometer?
correct speedo gear for my 3.08 gear
j-mod & valvebody pacman plate
96-98 mustang or markVIII flexplate
chip/tune for "03 transmission reads off of the park teeth, The sensor is a different height and the 6 holes in the shell no longer exist"
change from the circuit board connections to the older-style wire connections
Does anyone have anything to add or take away from this list?
Also will i be limited to a 3.27 gear in the future with the 8 tooth gear versus the 7 tooth gear on the output shaft?
Im new here, but Ive done lots of transmission stuff, it was all Lt1/LS1 though. I read as much as i could before posting a question.
kev93z is offline
post #2 of 19 (permalink) Old 09-14-2010, 07:42 PM
Check the oss count on the output ring gear, if it reads on the park pawl teeth you need to open the transmission up and swap that in there or your OSS count will be 24 counts per rotation instead of 6.
post #3 of 19 (permalink) Old 09-15-2010, 01:17 AM Thread Starter
Thanks for the response, i take it there is no way to fix this with a tune. Does the output shaft have to be removed for the swap & What is the average cost to tear down and change this at a shop? ive dealt with a local trans shop that has been reasonable on stuff in the past. The trans will be here soon and ill check to see what i have in there. I thought i was avoiding this once i had verifyed the speedo gear on the output shaft. Thanks for the help DD
kev93z is offline
post #4 of 19 (permalink) Old 09-15-2010, 07:51 AM
Darrin's Avatar
Lets start the simple way, can you get me the code off the plate on the side of the transmission that you are installing? Then we can decide what all needs to be done.
I hadn't replied yet because it sounds to me like you don't have the transmission with you yet to be able to answser the questions that I am going to have to tell you what you need to do. But, as long as you know that it has the drive gear on the output shaft then you can definitely do this job easily and without needing help from a shop.
The OSS thing is easily corrected in a tune if you have to deal with that, but if you honestly have an 03 Mach transmission then that won't at all be an issue though. That issue didn't come into play until the 04 model year.
I will also tell you now that there are things that are redundant and/or may not be needed at all in your list above. For instance a speedcal and the proper driven speedo gear. To help answer that one we need to know what rear end gears are in the car that this is going into. If the gears are stock then yes to the correct speedo gear and no to the speedcal. If you are going to 3.73 gears then yes on the speedcal and no on a new speedo gear.
The internal electronic setup needs to be swapped over to wires and the correct solenoids on this setup for the easy factor.
It all starts with finding out exactly what transmission you have though. When you get that code then post back up and there are several here who can answer as to what you need.
Darrin
Darrin is offline
post #5 of 19 (permalink) Old 09-15-2010, 10:43 AM
I prefer to dismantle the thunderbird transmissions and swap in the output shaft to help with the issues mentioned, as stated if it truely is an 03 it should be the correct count, but I am sure we have all seen transmissions tagged as the wrong year and that is a big change.
post #6 of 19 (permalink) Old 09-15-2010, 04:48 PM Thread Starter
Thanks for the help guys, Im pretty sure its an 03. The add stated:
"03 Ford Mustang 4.6L DOHC Mach 1 Transmission 2k
Fox Auto Parts is listing this used Automatic Transmission removed from a 2003 Ford Mustang with 2,000 miles on it".
But ya never know till its in your hands, as soon as i receive it Ill post up the info from the case. Thanks for the post this mornin darrin, it made my day.
kev93z is offline
post #7 of 19 (permalink) Old 09-24-2010, 10:29 PM Thread Starter
The trans showed up today. I snapped a few pics, one of the code plate. The 3rd pic down is the VSS hole with the splines, took several tries but still blurry.
kev93z is offline
post #8 of 19 (permalink) Old 09-25-2010, 08:43 AM
Darrin's Avatar
Can you remove the extension housing? It's just the 6 bolts and it pops right off. Then take a pic of the output shaft.
Darrin
Darrin is offline
post #9 of 19 (permalink) Old 09-27-2010, 10:14 PM Thread Starter
Finally had a minute to pull off the tail housing tonight. Will i have to replace the gasket when i put it back on? It looks to be in good shape.
kev93z is offline
post #10 of 19 (permalink) Old 09-28-2010, 06:46 AM
Darrin's Avatar
That is exactly what you want to see. Not only do you have the speedo drive gear on the output shaft, but everything looks clean and the rubber on that stopper that you see around the output shaft looks almost brand new. I always pull the extension housing on a used transmission because they get bounced around a yard and often have oil dry in them from where they cleaned them up.
Looks like you got what you were after. Good job and congrats!
Oh, and yes, you can re-use the gasket if it came off clean. I always replace them because they only cost a couple of bucks at most and there is no reason not to when you have about 50 hanging on the wall right in front of you
Darrin
Darrin is offline
post #11 of 19 (permalink) Old 09-28-2010, 08:21 AM
BUCK's Avatar
Thumbs up
Per Ford Manual Torque on the Tail Shaft / Extension Housing Fasteners is 19-22 Ft Lb & dab a tad of adhesive on cleaned Threads.
Last edited by BUCK; 09-28-2010 at 09:50 AM. Reason: Tq Spec Now Per Ford Manual vice ATSG Manual
BUCK is offline
post #12 of 19 (permalink) Old 09-28-2010, 09:03 AM
Darrin's Avatar
Originally Posted by BUCK View Post
Per Manual Torque on the Tail Shaft / Extension Housing Fasteners is 15-20 Ft Lb & dab a tad of adhesive on cleaned Threads.
Good info for him. I got excited about that thing looking as clean as it does and having the speedo gear that I forgot that he needs more info. LOL
OP, what all else do you need to know that you haven't gotten answered yet?
Darrin
Darrin is offline
post #13 of 19 (permalink) Old 09-28-2010, 02:22 PM Thread Starter
That is great news Darrin, I figured this trans was a good deal with the stall included and the low mileage. Thanks for the torque specs BUCK, i was gonna ask after a search but you beat me to it. I will list what im pretty sure I need to do and see if i have it covered.
swap my OSS sensor over
new 94 MLPS
speedo gear for 3.08 gear and when i can afford 3.73 ill get the speed recal
Remove the 2-3 spring/ i think im gonna keep the 1-2 in there
pacman plate to prevent leakage in valvebody
new converter nuts/solid rubb mount/merc v fluid
ok not sure on a couple things
j-mod for 98 up trans- does the 2003 trans still need this or has the factory covered it?
swap over the manual lever assembly?
any adjustment needed on the MLPS?
From what ive read it seems that this is a complete list, other than the couple things im unsure about. I cant wait to get started, my trans is getting weak and id ike to beat the cold weather.
kev93z is offline
post #14 of 19 (permalink) Old 09-28-2010, 05:42 PM
Darrin's Avatar
94 TCC solenoid & shift solenoids Yes
swap internal harness Yes
swap my VSS sensor over Yes
swap my OSS sensor over Yes
new 94 MLPS Yes
96-98 mustang or markVIII flexplate Yes
speedo gear for 3.08 gear and when i can afford 3.73 ill get the speed recal Yes
Remove the 2-3 spring/ i think im gonna keep the 1-2 in there maybe, I would use a different 1-2 setup
pacman plate to prevent leakage in valvebody If you insist.
new converter nuts/solid rubb mount/merc v fluid Yes
j-mod for 98 up trans- does the 2003 trans still need this or has the factory covered it? I would use this info http://www.crownvic.net/tech/4R70Wnotes.pdf
swap over the manual lever assembly? Yes
any adjustment needed on the MLPS? Trans in neutral and line up the neutral marks on the MLPS. Here is a link to a pic of that done correctly. www.bcatransmissions.com/properalignment.jpg
Hope that helps.
Darrin is offline
post #15 of 19 (permalink) Old 09-29-2010, 08:01 AM
BUCK's Avatar
I'm sure you're shopping for new Air to Tranny Fluid Cooler too.
BUCK is offline
post #16 of 19 (permalink) Old 09-29-2010, 12:16 PM Thread Starter
I've been looking at gettting a cooler, possibly the 45k BTU Tru cool. I was debating wether or not i could get away without one through the winter months.
Darrin thanks for the info, definitly feel better about tackling this now.
kev93z is offline
post #17 of 19 (permalink) Old 09-29-2010, 12:26 PM
Darrin's Avatar
That's a GREAT cooler, and you can get the one with the thermal bypass if you live in cold winter territory. You are after a Long Tru-Cool 4739 and I can get you one if you need it.
Just let me know
Darrin
Darrin is offline
post #18 of 19 (permalink) Old 11-08-2010, 10:23 PM Thread Starter
I finally have all the parts together to get started. I took your advice darrin and after some research purchased the brown & violet springs for the 1-2. I pulled the pan off and noticed there isnt a filter in the trans, im assuming they removed it since they sent a new filter with the trans.
I examined everything and noticed the connector on the PCS (in pic) looks like it might be different than the one on my 94 harness. Although im not sure since I havent removed my trans yet. I can tell the connectors are different on the new 94 shift solenoids and the new TCS. So im wondering if i need to change that PCS so i can connect to the 94 harness.
I ended up grabbing the autozone transcooler after reading about it here, also i had $20 on my rewards card so for $40 i couldnt pass it up.
I snapped a pic of the production date after noticing it on the bottom of the bellhousing. Looks like its a early 03 trans, or late 02 technically.
kev93z is offline
post #19 of 19 (permalink) Old 11-08-2010, 10:51 PM
BUCK's Avatar
Thumbs down
Nice clean Tranny - Can;t tell thickness but Cooler about same dimensions as mine but surely some will say too small... You may have done a tad better with your $40 on Ebay there.
BUCK is offline
