Help!! Car wont go pass drive after j-mod!! - TCCoA Forums
post #1 of 17 (permalink) Old 10-31-2010, 12:54 AM Thread Starter
Ok, i i finished in stalling my shift kit and deeper pan from Robert P.
I got everything finished, added some oil to the tranny, started the car, went inside to go throught the gears, and i cant go into drive.
park, reverse and neutral all work. I just cant seem to get it into drive.
I think its the shift linkage. You can pull the linkage off the tranny and manuely operate the gears on the trannsmission, they work.
Im at a lose here. Really dont know where to start?
Stuckinkaos07 is offline
post #2 of 17 (permalink) Old 10-31-2010, 05:18 AM
It is nice
Don't know if this is your problem but might wanna make sure it's on right...
http://img139.imageshack.us/img139/6682/jmod1.jpg
91CougarLS is offline
post #3 of 17 (permalink) Old 10-31-2010, 05:32 AM
I agree. Look at the picture, make sure the rooster pin lines up with the first indent.
post #4 of 17 (permalink) Old 10-31-2010, 09:17 AM Thread Starter
does the gear selector have to in park while i do this?
i also never took the roster tail apart
post #5 of 17 (permalink) Old 10-31-2010, 10:09 AM Thread Starter
ok, my rooster pin aigned and in the proper place as before. still nothing.
i really dont think its my new valve body. if i disconnect my shift selector from the tranny, i still get the same results. going into park, reverse, and neutral
post #6 of 17 (permalink) Old 10-31-2010, 10:28 AM
drop the pan and find out what inside on the valvebody is holding u back from shifting threw all the gears
1990 ford f150 5.0
1989 cougar xr-7 5spd 5.0 --249hp/[email protected]
1989 mustang gt [email protected]
1984 tbird 5.0 auto
1999 chevy tracker...wtf!!!!!
joker77_2005 is offline
post #7 of 17 (permalink) Old 10-31-2010, 11:49 AM Thread Starter
i pulled the shift selector all the way out of the car, its the shift seletor. When it gets to drive, it wont go back any further, but i can pry it back using a screwdriver. i think my gear seletor cable is shot. Looks like kym will without a car for a few days untill i can get to the junk yard and get another one.
anyone have any idea of why this would happened?
post #8 of 17 (permalink) Old 10-31-2010, 11:51 AM Thread Starter
its not the valve body, i have the pan dropped. if the gear selector on, it will only go so far. i remove the gear selector from roaster tail, and the rooster tail moves great.
i do have the pan dropped, and everything looks great.
post #9 of 17 (permalink) Old 10-31-2010, 12:46 PM
My shifter hangs up once in awhile. When it does I open it all up and just clean it. Those little overlapping plastic slides that surround the shifter handle itself like to gum up, trap crumbs and dirt, sticky beverage residue from the cupholders, etc. I take all that out and wash it in a bucket with dishsoap and water, and when it's dry it all goes back together and works like new again.
This is pretty easy to take aprt and reassemble; just pay attention to where everything was and don't bop yourself in the mouth pulling the shift knob off the handle.
Delete my account.
94 Thunderbird XX is offline
post #10 of 17 (permalink) Old 10-31-2010, 03:49 PM
dDUBb's Avatar
Did you unbolt the cable from the mounting bracket on the side of the transmission ?? If you didnt put it back in the right position it can bind up.
Unless you have something like loose change preventing movement inside your Shifter assembly.
dDUBb is offline
post #11 of 17 (permalink) Old 10-31-2010, 04:19 PM
ok so the cable is holding it up from shifteing any further.....its a girls car so ck for stuff doen in the shifter area
mike
1990 ford f150 5.0
1984 tbird 5.0 auto
post #12 of 17 (permalink) Old 10-31-2010, 06:12 PM
Dude I gurantee you it's not lined up proper I'll bet you
86 bird vortech s trim
10.75 @128.38
95 bird - Vortech t trim
1/8 [email protected]
10.11 @ 139.19 best mph
RobertP is offline
post #13 of 17 (permalink) Old 10-31-2010, 06:35 PM Thread Starter
I got it. Somehow my shift linkage got bent where the orange boot is. I did a little mod, and all is good. Now i just need to put it back into the car!!
I did not have to drop my valve body again. The roaster tail was properly installed. When i did the install, i had watched the valve body video from dirty dog as i did the install
post #14 of 17 (permalink) Old 10-31-2010, 08:18 PM
Good deal
10.75 @128.38
RobertP is offline
post #15 of 17 (permalink) Old 11-01-2010, 09:56 PM Thread Starter
Thanks for the hook-up. Im very pleased with the kit. I cant keep the tires from spinning in first and the 1-2 shift is great. I got nice firm shifts in the rest of the gears
post #16 of 17 (permalink) Old 11-02-2010, 01:34 AM
probly not as firm as the shift kit that was in my red bird is it?
mike
1990 ford f150 5.0
1984 tbird 5.0 auto
post #17 of 17 (permalink) Old 11-02-2010, 02:28 AM Thread Starter
mike
hell no, your red one was an electrically shift kit. mike can only do that with 94 - 96 4.6 cars withh obd ii systems.
i remember how hard that bad boy shifted and that washard as hell
