slipping of some sort - TCCoA Forums
post #1 of 10 (permalink) Old 11-03-2010, 10:10 PM Thread Starter
danalba's Avatar
at around 100 when its trying to shift into over drive i get a slipping feeling almost. it sounds almost like the TC is whinding really really high if that can even be heard. fluid level is good. fluid is a good color, no shutter. i have no ideas. any clue? almost the same thing that happens when the speed limiter kicks in, only it makes a funny really high whind noise like i said. it was just rebuilt at the beginning of april by a respectable shop here. could it be the tune?
MAC CAI/02 STANG MAF/SCT CHIP TUNED BY LONNIE
EIBACH 1.5 LOWERING SPRINGS- BILSTEIN GAS SHOCKS
90 SUPERCOUPE SIDE SKIRTS/REAR
18x9-FRONT: 245 REAR: 275
PI intake/PI cams
355 trac lok
new tune for swapped parts (93 oct)
no longer the owner.... but its still my child its just released into the world....
danalba is offline
post #2 of 10 (permalink) Old 11-04-2010, 12:55 AM
any gear change?
any torque converter change?
how does od function at lower speeds
1990 ford f150 5.0
1989 cougar xr-7 5spd 5.0 --249hp/[email protected]
1989 mustang gt [email protected]
1984 tbird 5.0 auto
1999 chevy tracker...wtf!!!!!
joker77_2005 is offline
post #3 of 10 (permalink) Old 11-04-2010, 11:04 AM
Could be a car that can't handle running that fast, most likely the overdrive band is cooked, however shifting into overdrive under load will never work. The slipping will change when the stub shaft breaks. Easy fix don't shift into overdrive while on the throttle trying to accelerate.
post #4 of 10 (permalink) Old 11-04-2010, 12:09 PM
What Alan said. NEVER try to do a 3-4 while you're on the gas because as he said, the stub shaft will break. Leave O/D lockout on, then if you decide you need to shift into OD once you're up near your RPM limit let off the gas, turn off the lockout, let it shift, then keep going.
post #5 of 10 (permalink) Old 11-04-2010, 07:18 PM Thread Starter
danalba's Avatar
alright i will do that. thanks for the help guys. btw it shifts fine when just cruising. OD works fine. just really threw me when it did this. it used to run fine all the way into 120 before getting it rebuilt. its not like i beat on it. just the occasional opening her up. but thanks for the help ill let you know.
and no, no gear change or TC change of any kind
PI intake/PI cams
355 trac lok
danalba is offline
post #6 of 10 (permalink) Old 11-04-2010, 09:21 PM
yea they can handle 700hp but not in stock trim....i believe the stock converter will ballon around 5500rpm...someone else can chime in and say
mike
1990 ford f150 5.0
1984 tbird 5.0 auto
post #7 of 10 (permalink) Old 11-04-2010, 11:46 PM
BUCK's Avatar
Thumbs down
don't see this prob on a Stock MK8 Motor w/upgraded Tranny & DD TC - I don't do any silly OD switch BS - & mind you running I'm running faster WFO than a stock T Bird - IMO it'll lock up & or DIE ~!
BUCK is offline
post #8 of 10 (permalink) Old 11-05-2010, 12:02 AM
Originally Posted by BUCK View Post
don't see this prob on a Stock MK - I don't do any silly OD switch BS with my DD TC - & mind you running I'm running faster WFO than any freaking stock T Bird - IMO it'll lock up & or DIE ~!
LOL, you go brother!!!
~Rick
TCCoA Sig
post #9 of 10 (permalink) Old 11-05-2010, 10:23 AM Thread Starter
danalba's Avatar
Must be nice haha.
however what Alan said was in fact the problem. keeping it out of od solved the issue. thanks again guys for putting what I thought was going to be an issue to rest. can sleep a little better now ha.
PI intake/PI cams
355 trac lok
danalba is offline
post #10 of 10 (permalink) Old 11-06-2010, 12:08 AM
BUCK's Avatar
Thumbs down
Mine runs fine thru 133 AFTER rebuild SO>>> based on your Quote above I say nothings fixed... it's FAR more likely upon scrutiny that your chosen Shop may lose some "respectability" :
Wrong OD Servo return Spring for you HP (per Jerry's Epistle) ? - UNupgraded smaller Diameter OD Servo ? - Did your guy use the improved O- Ringed Sonnax OD Servo Pin ? - Did he opt for the firmer engagement via the Sonnax Washer ? (I did'nt as I retained the old weaker Stub Shaft) - Main VB sub-assembly OD Servo Regulator has Brown / Orange Spring ? ... JMOD install error or VB install Torquing Error ? ... & maybe now a wounded OD Band.
http://www.sonnax.com/index.php
BUCK is offline
