Lubricating shift linkage - TCCoA Forums
post #1 of 6 (permalink) Old 01-15-2011, 10:26 PM Thread Starter
Whats the proper lube to use and method for lubing a shift linkage? Mine takes some effort to slide between gears.
'97 Thunderbird 3.8L V6
Pictures here
casper0522 is offline
post #2 of 6 (permalink) Old 01-16-2011, 10:09 AM
90birdlover1's Avatar
I have been using silicone spray. Seems to work great although , You need to use it often. But it doesn't seem to build up like some other lubes out there.
Larry
Larry
1990 T bird LX 3.8L working on 393 stroker conversion
2000 F150 XLT 4x4 Supercab 5.4L
2002 Eddie Bauer 4x4 Expedition 5.4L(wifes)
90birdlover1 is offline
post #3 of 6 (permalink) Old 01-16-2011, 10:10 AM Thread Starter
Thanks, I'll give it a try.
Pictures here
post #4 of 6 (permalink) Old 01-16-2011, 01:12 PM
Motorcycle cable lube works well; just make sure it's good quality. (it's silicone)
White lithium grease is good for the connections at the ends; be sure to clean out the old grease first. (light grease, not thick grease.)
WD40 will wash away all the lube, dry out, and let stuff rust. It's a solvent and drying agent, not a lube.
Be careful what you spray down with WD and forget about, lol.
post #5 of 6 (permalink) Old 01-16-2011, 01:46 PM
I just want to add that those little plastic slides (in the console, around the shifter handle itself) can make things difficult if they're gummed up.
I have to take mine out every 4 months or so to get a good cleaning.
Delete my account.
94 Thunderbird XX is offline
post #6 of 6 (permalink) Old 01-20-2011, 12:34 AM
ry2lazy4u's Avatar
Send a message via AIM to ry2lazy4u
check the shifter assembly. on either side there are plastic tabs that slide back and forth when you shift. The tabs usually break on the top. If you pop the plastic center console plastic piece off you can see the shifter mechanism. It may be broken. I have had to change 2/3 of my birds shifters over the years.
Three Birds are Better than 1! Current rides...
Red 96 LX 4.6 <----> Blue 95 LX 4.6 <----> Pearl 94 LX 4.6 (parts car!)
ry2lazy4u is offline
