Right turn = trans. slippage - common? - TCCoA Forums
post #1 of 12 (permalink) Old 01-22-2011, 05:22 PM Thread Starter
Recently my trans. will slip when cold if I turn right sharply.
Is this a common issue, or just old age?
Car has 174xxx miles on it, but I seem to recall reading about a similar issue on the 1995 tbird, and a replacement trans. pan to resolve the problem.
tsaign is offline
post #2 of 12 (permalink) Old 01-22-2011, 05:28 PM
Earl's Avatar
You need the 96+ trans pan with the dimple, which prevents fluid starvation on right hand turns...while you're there you might as well do a level 3 jmod and a big trans cooler.
Earl is offline
post #3 of 12 (permalink) Old 01-22-2011, 06:29 PM
This happens with me on the Cougar as well. As best as I can tell it's fluid starvation like Earl suggested.
FYI - doing the J-mod to an already dead trans won't help it much, if at all. The J-mod is preventive maintenance, not a repair.
post #4 of 12 (permalink) Old 01-22-2011, 08:07 PM
Earl's Avatar
well, that is true, I forgot to mention that
Earl is offline
post #5 of 12 (permalink) Old 01-24-2011, 04:39 PM
BUCK's Avatar
Thumbs up
Early 60's 2 Speed Ford O Matics did the same thing~!
BUCK is offline
post #6 of 12 (permalink) Old 01-26-2011, 08:26 AM
Did 1995 Mustang GT's with a 5.0 liter V-8 have 4R70W transmissions? I had a '95 Mustang GT that had that same problem; when I would make a right turn, at moderate speeds, the engine would rev up like the trans went into neutral for several seconds.
Of course, the Ford dealer could never find any problem!
post #7 of 12 (permalink) Old 01-26-2011, 08:55 AM
Earl's Avatar
Didn't the 5.0 mustang GT have a regular AOD?
Earl is offline
post #8 of 12 (permalink) Old 01-26-2011, 08:56 AM
No, they had AOD-E, but the pan would have been pretty much the same (no deep sump). So yes, fluid starvation.
post #9 of 12 (permalink) Old 01-28-2011, 10:54 AM
nall_one's Avatar
yep, the pans are pretty cheep at your local parts stores too, though if you have the original reusable gasket, i would keep it, their actually pretty good; i hate the aftermarket rubber things I'm using.
and its just slipping on right turns then? not on straight runs. i mean, if it isn't slipping all the time its probably OK for a Jmod. and it WILL wake up you vehicle, but if it's a daily driver, the 1-2 spring should probably stay in. mines out, and its a bit harsh if you don't know how to drive her just right. on an old drive-train I'm expecting failures any day now because of it.
nall_one is offline
post #10 of 12 (permalink) Old 01-28-2011, 03:08 PM Thread Starter
Is this the correct pan or no?
I'm sure it's the stock one that came on the car...but it does have a 'dimple' in it.
tsaign is offline
post #11 of 12 (permalink) Old 01-28-2011, 03:17 PM
No, the one you want will look like the one on the top right:
Alan (Dirtyd0g) can get you the pan and filter for a good price.
post #12 of 12 (permalink) Old 01-28-2011, 03:35 PM
nall_one's Avatar
yep, thats the one upper right. the dimple on yours is to hold the magnet ring in place in the pan.
nall_one is offline
