96 4.6 wont shift past 2nd gear and overdrive light is not responding - TCCoA Forums
post #1 of 9 (permalink) Old 02-16-2011, 01:15 PM Thread Starter
I'm working on a 1996 Thunderbird with the 4.6 engine. Transmission was shifting fine than all of a sudden with would not go past second gear. 1-2 shift a good with no lag or slipping. I have engine braking in manual 1,along with manual 2. From a take off the car with go 1-2 normally than hold 2nd until 36-37mph and than neutral out. If I engage manual second it kicks back into 2nd. If I keep it in drive while its neutraling out I can get second gear by rasing the rpm but it seem to slide than bump not bang back into 2nd. Also the over drive light does not have any effect during the neutraling not during acceleration. It wont light up with KOEO nor KOER. I have checked the fluid and it seems fine.
95Goldbird46 is offline
post #2 of 9 (permalink) Old 02-19-2011, 12:22 AM
A couple of possibilities, first might be a bad shift solinoid pack or MLPS not reading correctly, second could be a blown direct clutch accumulator/direct clutch piston cracked, direct clutch housing stripped/cracked, third possibility is a stripped/snapped stub shaft.
Solinoids & MLPS can be serviced in-car, everything else requires removal and teardown/rebuild.
Good luck,
Kevin.
KL Mallender is offline
post #3 of 9 (permalink) Old 02-19-2011, 09:47 AM
Darrin's Avatar
Right before this happened di you by chance have the car going really, really fast or did you get on it while in overdrive?
Darrin
Darrin is offline
post #4 of 9 (permalink) Old 02-23-2011, 11:15 AM Thread Starter
Would a bad solenoid pack cause the O/D light not to function? I wasn't driving it when this problem occurred but I doubt the driver was doing any hard driving(hes almost 50)
post #5 of 9 (permalink) Old 02-23-2011, 11:50 AM
BUCK's Avatar
Lightbulb
- Best of my knowledge Bad Solenoid would cause the OD Light to Blink provided Bulb is good thereby telling you it's stored a Tranny Code that documents the problem.
- Darrin helped me ID my bad Direct Clutch Drum during my Overhaul, per the Gurus it's a common failure.
& Grumpy old men like me can still do a little hard driving now & then...
BUCK is offline
post #6 of 9 (permalink) Old 02-23-2011, 12:28 PM Thread Starter
Ok well how about the MLPS would that cause dead o.d. light? I did pull the cluster and test the bulb it tested good. Also replaced PCM with a known good one. The trans not shifting is no big deal. Its the O/D light that bothers me. I have changed many birdy trans but dont want to put one in and have the same problem.
post #7 of 9 (permalink) Old 02-23-2011, 12:43 PM
BUCK's Avatar
Question
If OD Light never comes on first I'd Check the FUSE.
If Fuse is Blown first suspect is bad O/D Switch in Shifter.
2nd Suspect for blown Fuse is flooded MLPS Connector.
With Tranny not shifting & a good Fuse & OD Bulb I'm not understanading why OD Lite is not blinking - It should be.
BUCK is offline
post #8 of 9 (permalink) Old 02-23-2011, 12:54 PM Thread Starter
Ok im going to go pick up a mlps today and post the results this evening
post #9 of 9 (permalink) Old 03-01-2011, 07:40 PM Thread Starter
Gave it away to the neighbors it was a faulty MLPS.
