tranny keeps hitting rev limiter. - TCCoA Forums
post #1 of 11 (permalink) Old 02-17-2011, 01:56 PM Thread Starter
Smile tranny keeps hitting rev limiter.
have 4.6 tranny keeps hitting rev limiter and takes a second to shift.
tried adjusting the tv cable nothing has changed was wondering if any one had same problem or new of any way to fix it
car is stock only mod so far is 180 tstat and cut of the res back
im doing 0-60 in 7.14 i no it is faster it just takes for ever to shift
mike
mooseakarandle is offline
post #2 of 11 (permalink) Old 02-17-2011, 02:29 PM
1) You don't have a TV cable.
2) Have you changed the rear gears? If you haven't, the likely explanation is a worn out trans that slips during the shift.
post #3 of 11 (permalink) Old 02-17-2011, 02:30 PM
4R70s don't have a TV cable, what exactly did you try adjusting?
post #4 of 11 (permalink) Old 02-17-2011, 02:38 PM
I'll bet it was the cruise cable.
post #5 of 11 (permalink) Old 02-18-2011, 11:42 AM
BUCK's Avatar
Thumbs down
http://forums.tccoa.com/vbpgimage.ph...8&d=1263831413
I say toasted Roller Clutch & hence toasted Tranny.
BUCK is offline
post #6 of 11 (permalink) Old 02-20-2011, 10:49 AM Thread Starter
it was the cruze
but the thing is the tranny was rebuilt like 20000 miles ago
post #7 of 11 (permalink) Old 02-20-2011, 11:07 AM
BUCK's Avatar
Question
If they put the original style Roller OWC back in it vice the Mechanical Diode OWC it would'nt matter if it was Rebuilt last week.
BUCK is offline
post #8 of 11 (permalink) Old 02-20-2011, 01:13 PM Thread Starter
i dont have a clue what that means i had a guy tell me its just a sensor and its like 100 bucks to fix it and one guy didnt even put it on a lift and said it needs a rebuild so idk really
post #9 of 11 (permalink) Old 02-20-2011, 02:11 PM
You didn't mention which gear is slipping; 1-2, 2-3, or 3-4? Is this at wot? what rpm does it start shifting?
The way to find out what's wrong is to drop the pan and look at what's in the pan.
If there's no chunks of metal, you change the fluid, check the accumulator pistons (old style 1-2 sux), make sure the mlps is adjusted correctly, and try again.
But, I bet there's chunks of metal stuck to the magnet. The breakage above puts stuff everywhere; At that point, You need a tranny rebuild, new TC, and the cooler flushed really well. (You can't get all the crap out of the tc; some replace the cooler and lines as well. I'm not that extreme.)
post #10 of 11 (permalink) Old 02-20-2011, 07:54 PM Thread Starter
1st gear only around 45 to 50 mph tach dont work and what is mlps?????
post #11 of 11 (permalink) Old 02-20-2011, 09:34 PM
Manual lever position sensor, it's the black sensor on the left(driver) side of the trans
