Mark 8 MLPS wiring diagram - TCCoA Forums
post #1 of 17 (permalink) Old 02-22-2011, 04:19 PM Thread Starter
SuperNewbie
supergordo's Avatar
Anyone have a wiring diagram for the MLPS pinout and/or the wiring harness that is on the transmission? Need this for a 1997 Mark 8.
Thanks!
1995 Cougar XR7 4.6
1997 Thunderbird LX 4.6
1977 Country Squire 460
1985 Capri RS 5.0, 5spd
1997 Thunderbird 4.6
1984 Capri RS 5.0,5spd
supergordo is offline
post #2 of 17 (permalink) Old 02-22-2011, 08:07 PM
From a 1995 Mark VIII 4R70W:
~Rick
TCCoA Sig
post #3 of 17 (permalink) Old 02-22-2011, 08:55 PM Thread Starter
SuperNewbie
supergordo's Avatar
Thanks NetKeym. My only mistake is that I didn't post that I need this for a 1997. The MLPS has more pins. Thanks!!
1995 Cougar XR7 4.6
post #4 of 17 (permalink) Old 02-22-2011, 09:10 PM
Not A Problem! Ask and Ye Shall Receive: 1997 Mark VIII MLPS & 4R70W Wiring:
~Rick
TCCoA Sig
post #5 of 17 (permalink) Old 02-23-2011, 11:13 AM Thread Starter
SuperNewbie
supergordo's Avatar
Man that is absolutely perfect!
1995 Cougar XR7 4.6
post #6 of 17 (permalink) Old 02-24-2011, 11:33 AM
Hey Thanks for the diagrams!
Do you have access to more wiring diagrams for the mark 8's?
Of course! What do you need?
I need anything relating to the circuit that goes from the MLPS to the ECM, AND the shifter circuit. Specifically the LED lighting for the shifter that shows " P R N D 2 1"..
You mean the indicators on the dashboard or the ones by the shifter on the console?
~Rick
TCCoA Sig
post #7 of 17 (permalink) Old 02-24-2011, 12:19 PM Thread Starter
SuperNewbie
supergordo's Avatar
Specifically the ones on the shifter. However with the problem I'm trying to correct, having the dashboard diagram might not be bad either.
1995 Cougar XR7 4.6
post #8 of 17 (permalink) Old 03-01-2011, 07:31 AM
1997 Mark VIII Instrumentation Cluster
~Rick
TCCoA Sig
post #9 of 17 (permalink) Old 03-01-2011, 07:34 AM
1997 Mark VIII Instrumentation Illumination Wiring
~Rick
TCCoA Sig
post #10 of 17 (permalink) Old 03-07-2011, 09:35 AM Thread Starter
SuperNewbie
supergordo's Avatar
Awesome stuff! NetKeym, do you possibly have the diagram that shows the LED's for the shifter and in the dash for the PRNDL? Might be related to the info center, but I'm not sure.
1995 Cougar XR7 4.6
post #11 of 17 (permalink) Old 03-07-2011, 10:18 AM
Post #8 first pic above shows the LED's right in the center of the diagram & instrument cluster bulbs right under that. I'm not sure what else you are looking for.
~Rick
TCCoA Sig
post #12 of 17 (permalink) Old 03-07-2011, 11:22 PM
BUCK's Avatar
Thumbs up Should Be A Sticky
This awesome Thread should be stickied by Mod IMO ~!
BUCK is offline
post #13 of 17 (permalink) Old 03-08-2011, 05:05 PM Thread Starter
SuperNewbie
supergordo's Avatar
I must have missed it on my first look. Thanks, I'll check it again.
1995 Cougar XR7 4.6
post #14 of 17 (permalink) Old 03-08-2011, 05:07 PM Thread Starter
SuperNewbie
supergordo's Avatar
Yeah, I must have scrolled down to quickly the first time I looked at it.
1995 Cougar XR7 4.6
post #15 of 17 (permalink) Old 05-05-2011, 04:41 PM
i should have asked a long time ago. What does mlps stand for. I am looking for this in the parts section of a lot of auto part websites and i can't find it. Is there another name for it. Also is ford the only part to use when replacing this or is there any acceptable substitutes.
tino is offline
post #16 of 17 (permalink) Old 05-05-2011, 04:49 PM
Autozone/pepboys/etc. call it a neutral safety switch. It stands for manual lever position switch IIRC.
post #17 of 17 (permalink) Old 05-06-2011, 09:54 AM
Thank you for the info it is greatly appreciated.
tino is offline
