Transmission Cooler. - TCCoA Forums
post #1 of 38 (permalink) Old 03-01-2011, 06:09 PM Thread Starter
Cornell's Avatar
What do you guys have?
I found this and I might get it.
http://www.summitracing.com/parts/HDA-514
Im just looking for ideas for installation. I think I had read that installing it in the return line from the radiator line would be best?
I am running pretty much stock other then a few things here and there. Im going to do the J mod pretty soon and adding a cooler seems like it would be the right thing to do while im there.
That kit has 9/16 fittings, I read somewhere that its the same size of whats on my car, I yet still have to check that out.
Cornell is offline
post #2 of 38 (permalink) Old 03-01-2011, 06:15 PM
chris g's Avatar
Send a message via Yahoo to chris g
i've got mine installed on the return line.
COLD AIR INTAKE, MN12 PERFORMANCE FRONT SUSPENSION KIT, SILVER PAINTED AVS WINDOW GUARDS, SILVER PAINTED DASH PANELS, 28% MIRROR TINTED WINDOWS, SUSPENSION TECHNIQUES 2'' DROP, TRUE BENDS CUSTOM 2.5'' TRUE DUAL EXHAUST. 2nd generation SC wheels.
chris g is offline
post #3 of 38 (permalink) Old 03-01-2011, 06:40 PM
Most of us "SuperCharged" Carolina Birds & Ponys have this
Tru-Cool MAX transmission cooler 40,000 GVW rating, 45,000 BTU rating
post #4 of 38 (permalink) Old 03-01-2011, 08:29 PM
Someone was nice enough to make me a 3/8" kit to put my cooler in with.
You want it to go thru the cooler first, then the radiator, if you're not eliminating the radiator cooler.
With the big coolers, it keeps the fluid from getting too cool.
~180°F is still cool to a transmission.
post #5 of 38 (permalink) Old 03-01-2011, 09:12 PM
I can't wait to install my tru-cool 40,000 gvw cooler. Eventually....
post #6 of 38 (permalink) Old 03-01-2011, 10:25 PM Thread Starter
Cornell's Avatar
Yeah I saw that Tru-Cool from Robs website, I just think it be too big and unnecessary for stock application. At least thats what I think..
Cornell is offline
post #7 of 38 (permalink) Old 03-01-2011, 10:38 PM
I would recommend a stacked plate cooler over the tube and fin style like the one you have listed. Much more efficient and durable.
With my cooler on my J-modded and otherwise stock trans the temps usually peak at about 100 degrees over ambient temps when cruising on the freeway. E.G. 180 on an 80 degree day, 160 on a 60 degree day. I haven't seen more than 200 since I installed it.
B&M 70264; I didn't need any fittings to install it inline after the radiator tank exchanger other than what was included. I did get 3 extra feet of transmission fluid hose though.
post #8 of 38 (permalink) Old 03-01-2011, 11:05 PM Thread Starter
Cornell's Avatar
Yeah that B&M was the other one I had looked at. the 70264. I did not look deep into just because of the fittings issue. But if your right I might well just get that one. Ill go down to the parts store and see if they have one in stock I can look at.
Cornell is offline
post #9 of 38 (permalink) Old 03-02-2011, 07:08 AM
Darrin's Avatar
I would go to your local Autozone and ask for the cooler they sell that crosses to part number 679. It's stacked plate and may even cost you less than that one by the time you pay shipping.
Darrin
Darrin is offline
post #10 of 38 (permalink) Old 03-02-2011, 11:35 AM
SuperNewbie
supergordo's Avatar
Darrin
I've used the 679 cooler from autozone on several builds. Its a nice cooler for $60. I have the big Tru Cool on my car and I like it a lot. Though they are around $140 now days.
1995 Cougar XR7 4.6
1997 Thunderbird LX 4.6
1977 Country Squire 460
1985 Capri RS 5.0, 5spd
1997 Thunderbird 4.6
1984 Capri RS 5.0,5spd
supergordo is offline
post #11 of 38 (permalink) Old 03-02-2011, 11:44 AM
I got mine off amazon, paid $58 and free shipping.
post #12 of 38 (permalink) Old 03-02-2011, 12:52 PM
Darrin's Avatar
The 679 is a little bigger than the B&M 70268. The other thing I like about them is that you can usually go straight to the parts store and pick one up.
For those who don't have a parts store that has one handy, Amazon has the Hayden 679 for like $63 with free shipping right now.
Darrin
Darrin is offline
post #13 of 38 (permalink) Old 03-02-2011, 02:18 PM
Earl's Avatar
The only time I ever saw temps near or at or slightly above 200 degrees, was when driving through the desert and it was well over 100 degrees outside....other than that...
Mine is a 30,000 GVWR cooler...it's a hayden. From NAPA.
Earl is offline
post #14 of 38 (permalink) Old 03-06-2011, 04:57 PM
ROLLINTHUNDER's Avatar
Is the return line the only line you tap into for the aftermarket cooler? Do you tap in at 2 different locations as well? Taking care of a few odds and ends while waiting on a tranny. Thanks.
ROLLINTHUNDER is offline
post #15 of 38 (permalink) Old 03-06-2011, 05:01 PM
You can install it any way you want, the return line is most popular, however with a high stall you may need the feed line to prevent sending a that heat to the radiator. Some cases you bypass the radiator all together.
post #16 of 38 (permalink) Old 03-06-2011, 10:19 PM
driller's Avatar
If you have a HIGH stall converter, bypass it all together and use a BIG cooler.
driller is offline
post #17 of 38 (permalink) Old 03-07-2011, 11:34 PM
BUCK's Avatar
Exclamation
You do NOT want to end up like the dudes who have seen our Plastic ended Aluminum Cored Rads fail - It AINT pretty - I say delete the Rad Cooler PERIOD - I've seen some favorable changes in how my VCRM kicks in the Fan since I deleted the Tranny heat load fm Rad - Up North you'll need some kinda Fluid Temp Sensing Valve - I went with a brand new Ford P/N F4TH - 7A095 that I got new for $25 which is the optional Trans Cooler on the old Windstars but the Ford P/N has a nice bracket well suited to under Bumper installs on Mk's & Tbirds although it was probably in front of Rad stock (which I would NEVER do) - It's just a $60 B&M 70273 with a bracket - Compression fittings on existing lines cut at Passenger side & Hose Barb adapters to a short run of $3 a foot dude Hi Press line - & Yes this is one of the things you can shop to death on EBAY once you know what size & thickness your desired location will handle.
BUCK is offline
post #18 of 38 (permalink) Old 03-09-2011, 05:38 PM
Appreciate the info Buck. I'll just delete the rad cooler all together then. Just have to pick a good spot to mount it now. I have a hayden 403 ultra cool that ive had for years and just havnt installed it yet its still new in the box.
post #19 of 38 (permalink) Old 03-09-2011, 06:27 PM
This pic from Robstireandauto.com (RobertP) might give you a good idea on how/where to mount it. IIRC, that's on Trunk Monkey's car.
Delete my account.
94 Thunderbird XX is offline
post #20 of 38 (permalink) Old 03-09-2011, 06:36 PM
And mine from Roberts on a 96
post #21 of 38 (permalink) Old 03-09-2011, 07:21 PM
Thanks guys. I was thinking of mounting it there. It should be alright to lay it flat if need be shouldn't it?
post #22 of 38 (permalink) Old 03-09-2011, 08:24 PM
Marl's Avatar
Send a message via AIM to Marl Send a message via Yahoo to Marl
Hmmmmmmmm, I never thought of mounting it like that. I've got mine mounted up right in front of the a/c condenser. What kind of temps do you guys get with it mounted laying down like that? I mounted mine up so if I was stopped in traffic the fan might pull some air thru it.
1995 4.6L XR7 Dual Guage Pod with Oil and Temp., 255/60R15 Yokohama Avid S/T's, Screamin' Demon Coil's with Live Wires, K & N, modified stock oil pressure gauge, air silencer removed, stock air box, trans and tune by Darrin, TC by Dirtydog
Sometimes when I reflect back on all the beer I drink I feel ashamed. Then I look into the glass and think about the workers in the brewery and all of their hopes and dreams. If I didn't drink this beer, they might be out of work and their dreams would be shattered. Then I say to myself, 'It is better that I drink this beer and let their dreams come true than to be selfish and worry about my liver.'
Spend your money on your ride and not your girl. It'll last longer and fewer people have been in it!
Marl is offline
post #23 of 38 (permalink) Old 03-09-2011, 08:28 PM
I average about 160 and has never gotten to 200, that's after some runs on a hot day at the 1/4 mile
post #24 of 38 (permalink) Old 03-09-2011, 08:49 PM
Marl's Avatar
That's pretty much what I run temp wise. Now I just need to figure out what the a/c problem is before summer hits........
Marl is offline
post #25 of 38 (permalink) Old 03-10-2011, 12:15 AM
BUCK's Avatar
Thumbs up
That big cooler a VERY nice use of the area Ford blessed us with - My cooler a fraction of that... Maybe 1/4 the length & no probs as I;m not on the strip & only a slightly tweaked 11inch D/D TC.
BUCK is offline
post #26 of 38 (permalink) Old 03-23-2011, 06:47 PM
Ok i got the cooler mounted today. Right to the side of the oil cooler and has a slight angle for better flow through. I ordered a tranny cooler install kit from Jegs for 7 bucks that worked awesome. Now i was thinking of installing a tranny temp sending unit for my gauge thats already mounted and I was wondering if anyone knew if any of the auto parts stores carries any that would works? It's an elecrical type gauge. Thanks.
post #27 of 38 (permalink) Old 03-24-2011, 09:14 AM
BUCK's Avatar
Question
I thought you could pick up Temp fm Factory Sender in Pan off the PCM somewhere... am I wrong?
BUCK is offline
post #28 of 38 (permalink) Old 03-24-2011, 09:22 AM
Accuracy of the factory stuff is not good.
post #29 of 38 (permalink) Old 03-24-2011, 04:32 PM
If you want accuracy you are going to have to get the sender that matches your guage.
PaulS1950 is offline
post #30 of 38 (permalink) Old 10-08-2011, 06:20 PM
N8tiveJuggalo17's Avatar
I live up in the southwest corner of southdakota where temps vary from 0° in the winter up to 100° in the summer, I just purchased the 9.5" 3800 stall billet front cover torque converter & 373 trak-lok rear end from DirtyD0g, I bought they hayden 679 with 3/8 line from him also. My question is i was wondering how to run the cooler? He advised stand alone but if the weather gets really cold in the winter would thing cause problems for me? the tranny fluid being too cold? should i run rad-> cooler-> tranny? or just through the 679 and back to the tranny?
---Jeremy
N8tiveJuggalo17 is offline
