Somebody running a 4r70w on a carb engine ??? - TCCoA Forums
post #1 of 2 (permalink) Old 03-15-2011, 04:00 PM Thread Starter
Question Somebody running a 4r70w on a carb engine ???
hi folks
is actually somebody here who has a 4r70w behind a carburated motor??
and how is it coming around???
Bad-Hoschy is offline
post #2 of 2 (permalink) Old 03-15-2011, 08:38 PM
there is 2 ways that you can do it.
1: put 4R70W parts into a 4R70 trans with a manual valve body
2: get a electronic programmer to control the electronics in the 4R70W transmission
option 1 is the cheaper way of doing it. I had a friends dad put the trans together for me but you will need a upgraded valve body to run the newer gear set. also note this was put into a 90 grand marq so it did have fuel injection but the only electronics to the trans where for PARK switch and the Rev. lights, so should still work in a carb engine.
95 Thunderbird LX
Drive train Mods:
full PI swap (03 grand marquis engine), 2000 Mustang GT 4R70W, C & L intake elbow, 73mm TB, 73mm MAF housing, CAI, flowmaster exhaust, 3.73 w/ trac lock and upgraded clutches, BOC tune.
Interior Mods:
SC seats
2008 Mazdaspeed 3
Drive train Mods:
Mazdaspeed cold air intake, TWM short throw shifter, motor mounts, and muffler delete
autoxbird is offline
