Transmission temperature Sending Unit - TCCoA Forums
post #1 of 14 (permalink) Old 03-26-2011, 04:51 PM Thread Starter
southbound's Avatar
Question Transmission temperature Sending Unit
Ok so I finally got around to having the dirtyd0g tranny I bought from JamesD installed this past week... All seems to be in order except one thing the shop could not figure out how to install the temp sending unit I got with the Auto Meter 5757 tranny temp gauge.They said the threads in the deep pan are course pipe threads and the brass fittings are not and in short just gave up... So now it has been towed to the next county to have the true duals installed and when it comes home next week I need to find a way to fix this... I have a triple gauge pod ready to go in as soon as I get the car back and want all the gauges to work...
So I know this has been done and yes I have tried the SEARCH function to no avail..Anyone with the answer?? I would like to have what I need ready before I pull the plug. Replacing all that new fluid is gonna make me mad...
On the plus side I got to move the car across the lot today and it sounds nice with open manifolds....
Thanks!!!!!
southbound is offline
post #2 of 14 (permalink) Old 03-26-2011, 05:11 PM
Get a cast alumium pan, drill and tap it for the temp sensor.
post #3 of 14 (permalink) Old 03-26-2011, 05:13 PM Thread Starter
southbound's Avatar
It has the cast aluminum pan from you... Do you know the drill and tap size???
Thanks...
post #4 of 14 (permalink) Old 03-26-2011, 08:52 PM
It depends on the kit it should be listed in the instructions. Most are 1/8npt.
post #5 of 14 (permalink) Old 03-26-2011, 08:56 PM Thread Starter
southbound's Avatar
Sorry I did look it up and it is 1/8 NPT..
I should have updated the post..
Thanks.....
post #6 of 14 (permalink) Old 04-01-2011, 02:03 PM
Cornell's Avatar
Dont mean to hi jack but....
Would it be better to install the unit on the line going from the trans to the radiator?
Just read that on the article saying that its the hottest fluid.
Which is what I might do. Even if the kit I have recommends the line going back into the trans to check the temp of the fluid going back in...
Cornell is offline
post #7 of 14 (permalink) Old 04-03-2011, 05:54 PM Thread Starter
southbound's Avatar
Lots of opinions on that and I am not sure what is best...
post #8 of 14 (permalink) Old 05-22-2011, 06:51 PM
Rob
Rob's Avatar
Send a message via AIM to Rob
I would like to hi-jack this thread also. I am thinking about installing a temperature gauge for my transmission fluid. Can I put the electric sender in the pressure port on the LH side of the transmission case? This one is cool because it has a wire instead of a thermocouple. If not here, I am thinking about doing it in-line. I dont want to deal with putting a hole in the trans pan. Let me know whats up. Thanks in advance.
Is it a bad idea for the sender to "see" pressurized fluid? I am worried it will possibly blow out.
-Rob
Rob is offline
post #9 of 14 (permalink) Old 05-22-2011, 09:39 PM
I wouldn't do that it will not be accurate. I suggest for one sensor use the pan. For 2 sensors use the hot and cold side of the cooler.
post #10 of 14 (permalink) Old 05-22-2011, 10:41 PM
Rob
Rob's Avatar
I think I could rest easier knowing the sender isnt under pressure. I guess I will weld in a bung on the pan for the sender sometime. I think it's 3/8 NPT. Thanks for the reply
-Rob
Rob is offline
post #11 of 14 (permalink) Old 05-23-2011, 12:10 AM
I think you may want to weld a bung in the pan, that's the way I've seen it done usually.
John Fritz is offline
post #12 of 14 (permalink) Old 05-23-2011, 12:22 AM
It's worth buying a cast aluminum pan for.
post #13 of 14 (permalink) Old 05-23-2011, 03:01 PM
With a bung already in it? Are they available that way?
post #14 of 14 (permalink) Old 05-24-2011, 02:27 PM
I can and do tap the cast aluminum pans I sell for people provided they can tell me exactly what size they need for their setup.
