Trying to figure out this shuddering problem.. - TCCoA Forums
post #1 of 10 (permalink) Old 04-12-2011, 12:32 PM Thread Starter
I bought my 3.8 95 cougar and two weeks after 3-4 went so i installed a junkyard tranny which was fine..and all i could afford at the time and when im driving on straight and level streets sometimes ill get a shudder from 1-2, the trans is filled with castrol mercon v as well as a quart of lucas as well as a new filter which i replaced with the trans.
Im also trying to figure out why it hesitates from a stop in drive not in manual 1 or 2. Ive learned to live with these problems but i would also like to know if anyone has similar problems
Thanks, Zach
k40XR7 is offline
post #2 of 10 (permalink) Old 04-12-2011, 06:04 PM
Combatspace's Avatar
I also have this problem in my '96 4.6L. Any help would be greatly appreciated.
Combatspace is offline
post #3 of 10 (permalink) Old 04-12-2011, 06:55 PM
Probably need a new converter, very common.
post #4 of 10 (permalink) Old 04-12-2011, 08:22 PM
Thought that might be it, but needed someone's opinion with trans knowhow. Thanks, DD.
post #5 of 10 (permalink) Old 04-13-2011, 04:10 AM
tbird_boi82's Avatar
Send a message via AIM to tbird_boi82 Send a message via Yahoo to tbird_boi82
Definately the TORQ CONVERTER , I had that problem changed the TQ out and no more problem .Shop around when you get one I found a rebuilt for mine for about 85 bucks.
97 4.6L
tbird_boi82 is offline
post #6 of 10 (permalink) Old 04-18-2011, 07:46 AM
1/2 shudder
Can someone explain how a Torque Converter that does the same function in all gears, only causes a problem on the 1/2 shift?
Most likely the concern is the Intermediate Clutch or the Intermediate One-Way Clutch.
I suspect the "hesitation when in drive" that you have is acutally a No 2-1 downshift and as you step on the gas, it forces the trans to downshift into 1st gear.
When in Manual 1 or Manual 2 position, no automatic downshift occurs.
When you take the torque converter out, remove the front pump and check the Intermediate clutch plates for warp or burnt(black) areas. There is also a bleed hole in the Intermediate clutch piston that MUST be oriented at the 12 o'clock position. Hopefully you got some kind of warranty with that trans.
5.4LDOHC is offline
post #7 of 10 (permalink) Old 04-18-2011, 10:10 PM
BUCK's Avatar
Question bleed hole in the Intermediate clutch piston that MUST be oriented at the 12 o'clock?
- Doesn't the damned thing spin 360 degrees ? - NEVER seen this before & if it's in Manual I missed it ~!
- Wondering what the Gurus have to say on this __________ ??
BUCK is offline
post #8 of 10 (permalink) Old 04-18-2011, 10:14 PM
Maybe it's just shuddering because it's cold out!
Whaaaa Whaa Whaaaaaaaaaaa
~Rick
TCCoA Sig
post #9 of 10 (permalink) Old 04-19-2011, 09:04 AM
Intermediate bleed Hole
BUCK,
Don't feel bad, alot of people miss this. The piston doesn't rotate, It is held in place by a metal retainer. The workshop manual has this in it but it doesn't call it out by printing in BOLD or equivalent. It is in the Disassembly/Assembly of Subassemblies section. The bleed hole is the only round hole in the pistion and must be positioned to 12 o'clock.
5.4LDOHC is offline
post #10 of 10 (permalink) Old 04-20-2011, 10:04 PM
BUCK's Avatar
Thumbs up
It's in BOLD in the POS ATSG p99 that I keep in Office - I'll check the real Ford Manual I keep in Garage... Thank God I must have gotten it right.
BUCK is offline
