How many miles too many on used trans? - TCCoA Forums
post #1 of 8 (permalink) Old 04-14-2011, 08:23 AM Thread Starter
I have two local yards with used trannys for my 97 Bird. I can get a very low-mileage one for about $450, or one with 195K for about $175. Seeing as how I'm paying labor to put it in, and the car has about 145K on it and no certainty that something else won't break in the near future, would you go for cheap or lower miles?
shumbody is offline
post #2 of 8 (permalink) Old 04-14-2011, 12:49 PM
Low miles and as new as possible, 200k is way too much. I wouldn't buy a used trans with more than 50k frankly.
post #3 of 8 (permalink) Old 04-14-2011, 01:54 PM
Yeah, I definitely wouldn't put a trans with 195K into my car unless it was a last resort. Also, while looking for a trans, see if you can get one out of a 98 or newer Mustang, as that will give you a stronger trans and also a slightly better converter.
post #4 of 8 (permalink) Old 04-14-2011, 10:41 PM Thread Starter
What mods required for a newer Mustang trans?
shumbody is offline
post #5 of 8 (permalink) Old 04-15-2011, 10:01 AM
Re-pinning a connector and swapping your MLPS sensor onto the new trans, and that is it.
post #6 of 8 (permalink) Old 04-15-2011, 01:38 PM Thread Starter
Sweet. 1998 through what year? Also, what about Grand Wags and Crown Vics? Will their 4R70W's work too?
shumbody is offline
post #7 of 8 (permalink) Old 04-15-2011, 01:40 PM
As long as they aren't police versions they work. with mustangs you want 98-03 since they lost the speedo drive teeth on the output shaft after that. AFAIK all of the CV/GM trans's will work.
post #8 of 8 (permalink) Old 04-15-2011, 01:44 PM
CV/GM trans will work, like was said as long as it isn't the police version. Also Town-car transmissions are the same as the police crown vic, and will not work. The advantage to the Mustang one is you get the smaller converter, which gives you a slightly higher stall speed and allows you to rev slightly higher, however even a 98-03 CV/GM trans will be a vast improvement over what you already have.
