shift kit 101??? - TCCoA Forums
post #1 of 7 (permalink) Old 04-14-2011, 11:44 PM Thread Starter
shift kit 101???
i went to a local trans shop today too see how much it would be to get a transgo shift kit installed and they said they wouldnt even work on my trans becuase its a 94. but i only have 114k so wtf idk.. he was trying to tell me that it would completely ruin my trans, but my trans is perfectly fine right now. any help? what exactly does the transgo do that would harm my trans??? which is better transgo or jmob? and where in the phoenix valley can i get a Jmod?? please help.;
jmtbird94 is offline
post #2 of 7 (permalink) Old 04-15-2011, 03:24 AM
I don't blame them the transgo kit is garbage. The jmod is a separator plate change along with updated shift accumulators and different springs. You may want to ask a trans shop that does custom work to help you out with it since places like ammco and cottman aren't going to do it want to do it for you. Or you could invest in the tools and do it yourself or find someone from here in your area that might want to help you. It may seem like a hike but if all else fails you could come out here To Vegas and Supergordo (Gordon) might do it for you. Shoot him a pm if your willing to drive all that way.
post #3 of 7 (permalink) Old 04-15-2011, 03:40 AM
Also it's worthless to do a shift kit to in unless your also doing a fluid change to mercon v and adding a transmission cooler and because it's a 94/95 transmission you'll also want to upgrade the transmission pan and filter to the 96/97 parts.
So a brief run down:
Jmod parts
New 1-2 accumulator
New 2-3 accumulator
New Shift spring
Redrilled separator plate or new separator plate or refurbished, etc...
Upper and lower valve body gaskets
Other parts while your in there:
Main pressure regulator valve
Larger 3-4 shift servo and spring
96/97 transmission pan (or aftermarket)
New ford transmission pan gasket (if yours is original or aftermarket)
Transmission cooler
12-14 quarts of your brand choice of mercon v transmission fluid.
And of course labor
I'm also not 100% sure about the 94/95 stuff but iirc they benefit from the new valvebodies, but hopefully someone else will chime in with that information for you.
post #4 of 7 (permalink) Old 04-15-2011, 10:39 AM Thread Starter
post #5 of 7 (permalink) Old 04-15-2011, 07:46 PM
sousa632's Avatar
Just talk to RobertP or DirtyDog here and get their Jmod kit.
John
1996 TBird LX 4.6
2001 Sable Wagon 3.0 Duratec
sousa632 is offline
post #6 of 7 (permalink) Old 04-15-2011, 07:50 PM
X2 That is the best way to go with your trans
post #7 of 7 (permalink) Old 04-15-2011, 07:55 PM
I have a 95 J-Modded with pretty much the upgrades in Murder's post up above and I absolutely love and recommend it wholeheartedly!
~Rick
TCCoA Sig
